Old 02-17-2010, 02:17 PM   #51
Ilike 72"s
Re: New Years purchase
I was wondering what the seats were. Very clean floors. Yes the doors have popers on them controled by the key remote.
Ilike 72"s is offline   Reply With Quote
Old 02-21-2010, 11:11 PM   #52
Ilike 72"s
A few steps backwards and a few forward.
First the backward
Engine has major damage to the pistons, all eight have the ring landings shattered. Debris down the cylinders scored the cylinder walls. Total tear down and back to the machine shop.
Machinist told me it was caused by old gas which caused predetonation which caused extreme cylinder pressure that busted the pistons. All in only 8 miles on the engine.
Now the forward.
Got the new carpet and installed it. I like the loop style. Found another center console and installed it and the CD changer under it. Removed the dash cluster and installing the Auto meter gauges into it. Removed the gauge trim rings and glass and using the original lens to mount to.
Pulled the rearend cover and checked the lash and backlash. Good setting, and found it has 4.11 ratio.
Old 02-21-2010, 11:13 PM   #53
VA72C10
VA72C10
VA72C10's Avatar
wow, sorry bout the engine...hope it doesn't take out all your profits when you sell it.
Old 02-21-2010, 11:27 PM   #54
Ilike 72"s
I enjoy working on these trucks--but-- yes it will hurt. About a $1,000 dollar hurt. Bad thing is that I knew better. The Jimmy sat for around a year and the gas smelled really bad, but I drove it 4 miles to the gas station and back.
Old 02-22-2010, 01:30 AM   #55
mcbassin
Still Learning
mcbassin's Avatar
That really sucks to hear about your engine. I have never heard of that. The carpet really looks great in there!
Old 02-22-2010, 11:31 AM   #56
Ilike 72"s
Thanks,
I hope to have the engine back wednesday. I will assemble it AGAIN and hope to have it in and running this weekend.
The bad (old) gas is more volitile and can ignite and explode while in the compression stroke. That exploding gas puts pressure down on the piston while it's still comming up. Then it fires again when it gets to the top when it should. All this creates tremendous heat and pressure in the cylinder. Thats when the ring landings cant hold the ring, and it breaks.
NOW you have more heat and pressure going down the side of the piston, heating the side of the piston and getting in the crankcase. Now you also have pressure in the crankcase hammering up on the ring landings also. Every thing goes to s#!t.
Old 02-28-2010, 11:39 PM   #57
Ilike 72"s
Got all my machine work done. Decked the block and bored to .040 over. Turned the crank .010 under. Surfaced the heads.
This time I installed new pistons and rings. New bearings through out. True roller chain and roller cam with roller lifters. New harmonic balancer because the old one had a wobble. More important is that I replaced the old gas.
Old 02-28-2010, 11:49 PM   #58
Ilike 72"s
Back together and running. Set the timing at 14 Before TDC and 34 total advance. Runs real smooth and has lots of torque. I put 40 miles on it today in the sun.
Old 02-28-2010, 11:51 PM   #59
VA72C10
VA72C10
VA72C10's Avatar
Congrats on getting it back together. Glad you got to enjoy it with the top down.
Old 02-28-2010, 11:53 PM   #60
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good. alot of great progress.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-01-2010, 12:38 AM   #61
Ilike 72"s
Thanks,
I'm now going to install the Auto Meter gauges into my cluster by attaching them to the back of the original lens. Clean up the wires behind the dash.
Need to center the steering, It turns sharp one way but not the other.
Old 03-05-2010, 11:17 AM   #62
Ilike 72"s
pic
Old 03-28-2010, 10:43 PM   #63
Ilike 72"s
Todays picture
Old 05-11-2010, 12:29 AM   #64
Ilike 72"s
Time to move on to the next project. Hate to see it go. This thing has amazing power on the highway. When you want to pass, It gets it done in a hurry. If I was to keep it I think I would install a 750 dbl pumper, roller rockers and a set of headers. From what I read that would put me close to 425 HP and torque would be way up there. But it all ends here for me on this one.
It's Ebay sale ends at noon pacific time tomorrow. Wish me luck. DENNIS
