Old 03-09-2010, 08:28 PM   #1
crapy67
White wall terror
crapy67's Avatar
3/5 drop
I have a 71 lwb and I want to do a 3/5 drop using only coils, I want to use the factory hieght spindles. My first question is how will the ride be since its my daily driver, And would I need lowering shocks for it. Thanks in advance for any information... Mark
crapy67 is offline   Reply With Quote
Old 03-09-2010, 08:40 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: 3/5 drop
Heard its not good to do all lowering with springs, you CAN I guess...
supposed to be better with drop spindles .5" spring and drop shocks/relocators supertrac bar etc
John
1999 Toyota Tacoma 4x4
Old 03-09-2010, 08:45 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Re: 3/5 drop
It will ride a lot better with dropped spindles as opposed to dropped coil springs. I would go that route if it is a daily driver.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-09-2010, 09:12 PM   #4
crapy67
White wall terror
crapy67's Avatar
Re: 3/5 drop
I thought it might ride a bit rough with just the coils, My budget won't allow me to get spindles though.
Old 03-09-2010, 09:28 PM   #5
OhOneWS6
OhOneWS6's Avatar
Re: 3/5 drop
Wait until you have the money for the spindle or do a 2/4 drop.
OhOneWS6 is offline   Reply With Quote
Old 03-09-2010, 09:37 PM   #6
crapy67
White wall terror
crapy67's Avatar
Re: 3/5 drop
A 2/4 drop won't ride as bad?
Old 03-09-2010, 09:49 PM   #7
Jim_PA
Re: 3/5 drop
Alignment can be a pain with a coil drop too. With spindles you are changing the geometry much less.
Jim_PA is offline   Reply With Quote
Old 03-09-2010, 09:49 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 3/5 drop
I've done it a lot of different ways over the years. In my experience, 2 inch drop springs ride very well. If you want more drop from springs, they ride better with cut stock coils than they do with pre-made 3 inch springs. You can cut one coil from the stock springs to get a 3 inch drop and it will be much more comfortable than specific drop springs.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-11-2010, 06:59 PM   #9
crapy67
White wall terror
crapy67's Avatar
Re: 3/5 drop
Yeah Tx I thought about cutting a coil, but the springs are so worn out I thought I might as well replace them.
Old 03-11-2010, 09:50 PM   #10
blyguy
blyguy's Avatar
Re: 3/5 drop
did a 3/5 on mine with coils and it rides good but had it at the alignment shop today and they could only get it close, said i need a longer stud on the drivers side to get it right. he didnt recommend i do that he suggested doing a spindle. going to try another shop to see if they can put the longer stud in, spindles are not in the budget right now.
1971 Chev C-10 SWB CST
2008 Chev 1500 Crew Cab LTZ
2010 VW EOS
2007 Harley Davidson Nighttrain
blyguy is offline   Reply With Quote
