Old 03-25-2010, 09:07 PM   #1
67Slider
67Slider's Avatar
Accelerator Pedal
Does anyone know of a way to put a different accelerator pedal on a 67? I saw LFD's design (it is cool) but I don't have the $$$$$ to buy a cable and the bracket. Any suggestions? I just really hate the nipple on the floor design.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 03-25-2010, 09:21 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Accelerator Pedal
There's a writeup in the FAQ to do it low budget, but you'd still need the pedal and cable. http://67-72chevytrucks.com/vboard/s...00#post1383300
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-25-2010, 09:45 PM   #3
67Slider
67Slider's Avatar
Yeah. Looks like FUN!!!! I was hoping there was a bolt-on out there that would be the simplest thing for me. But since I already have the 71-72 bracket, pedal and plastic I will probably undertake this project. Wish me luck...
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 03-25-2010, 09:48 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
Cool, let us know how it turns out.
Beat it to fit,
Old 03-25-2010, 09:55 PM   #5
67Slider
67Slider's Avatar
Does this use a 71-71 accelerator cable?
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 03-25-2010, 09:56 PM   #6
67Slider
67Slider's Avatar
71-72.....Sorry
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 03-25-2010, 09:59 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
Not sure, probably but read the writeup and see.
Beat it to fit,
Old 03-25-2010, 10:03 PM   #8
67Slider
67Slider's Avatar
I read thru it and it doesn't say. I wil PM Putter and see what he says.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 03-25-2010, 10:29 PM   #9
Sinister
Between Trucks...
Sinister's Avatar
Looks like he uses a '71-'72 cable in the writeup.
Beat it to fit,
Old 03-26-2010, 06:35 PM   #10
67Slider
67Slider's Avatar
Well...I got the accelerator put in. It was a little more than an hour tho...more like 6. But I guess that counts the two trips to the auto part store and the trip to the local shop to use their vice. But end result is COOL! I took pics and tried to post but the web page keeps telling me they exceed the file size. I guess next time I will turn the camera down to "fuzzy" when I take pics. I ended up using a 74 throttle cable and had to trim it down to fit, then use a cable stop on the cab side end of the acelerator linkage. Works great tho, nice and smooth like its supposed to be. Thanks for all the great tips.
Accelerator setup from the junkyard - $10
Accelerator cable and end stops - $20
Working on my old truck with my 8 year old son - Priceless
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 03-26-2010, 06:38 PM   #11
Sinister
Between Trucks...
Sinister's Avatar
That's great, glad it went well for you and your son.
Beat it to fit,
Old 03-26-2010, 08:23 PM   #12
67Slider
67Slider's Avatar
Ok.... Here is the throttle cable from the fire wall to the carb. Looks pretty clean I think.
[IMG][/IMG]
And here is the finished pedal assembly in my 67
And here is my son, Perrin testing the new linkage and pedal. He says it sounds like a racecar.
Thanks for the info and now I can post pics.
Right on!!!!
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 03-26-2010, 08:29 PM   #13
67Slider
67Slider's Avatar
I thought so too. But too late now. How much curve do I need?
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 03-26-2010, 08:30 PM   #14
Sinister
Between Trucks...
Sinister's Avatar
I deleted my post about more throttle cable length, didn't want to bum you out to bad. You probably want a couple of inches of leeway to account for engine movement, but that's with a fixed throttle cable bracket which I don't see. Might still be a good idea though.
Beat it to fit,
Old 03-26-2010, 08:35 PM   #15
67_C-30
I have a radical idea!
67_C-30's Avatar
What did you use to put the square hole in the firewall?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-26-2010, 08:49 PM   #16
67Slider
67Slider's Avatar
Drilled a hole with the biggest bit my puny a$$ drill could take and then used some files to square it out. Took about 1/2 hour to square out streching across the motor!!!!!! Not too bad tho.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 03-26-2010, 09:10 PM   #17
67_C-30
67_C-30's Avatar
Do you think it could be done from under the dash. I totally dumbed out and didn't do it when I put the diesel in my C-30 and now I'm going to have do it with it in the truck. This thing huge and very tight for space.
My trucks
Old 03-26-2010, 09:12 PM   #18
Sinister
Between Trucks...
Sinister's Avatar
I think it would actually be easier to do it from the dash side.
Beat it to fit,
Old 03-26-2010, 09:21 PM   #19
67Slider
67Slider's Avatar
I drilled the hole from the dash side so it can be done from either side I would think. It was just 65 outside and not too windy so I wanted some sun on my neck. Snowing now. Gotta love Colorado weather.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 03-26-2010, 09:34 PM   #20
67_C-30
67_C-30's Avatar
Good to hear! Thanks guys!
My trucks
