Old 04-02-2010, 11:40 PM   #1
rgreathouse
67/68 suspension difference from 69/72
What is the difference in the frame and or suspension on 67 and 68's from 69-72's?
I see some lift kits that are only for 69-72 4x4. Also the DIY4x.com fgb52 says it is made for 69-72 chevys.
So what is different? Or will everything fit the same?
Thank you
Robert
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 04-03-2010, 12:39 PM   #2
rgreathouse
Re: 67/68 suspension difference from 69/72
anyone? I am thinking about buying a 68' chassis and would like to know if the fgb52 will work?
Old 04-03-2010, 09:33 PM   #3
1969K10
1969K10's Avatar
my understanding is that the '68 springs were wider. you might be able to modify your bushings to fit. I think the '67 was diffrerent still, but not sure why.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-04-2010, 01:32 AM   #4
rgreathouse
I have researched and found that some people say 67-68 leafs taper from 3" to 2.5" on the axle perch to 3" to the shakle. If this is so I am assuming the frame it self is the same but the spring hangers are different.
Is this correct?
Thank You
Robert
Old 04-10-2010, 01:31 PM   #5
bigbadchev72
People know me
bigbadchev72's Avatar
the steering arm is totally different as well and the gear box too. I have a 67 that has the 69-72 6" leafs on it with a newer steering box(69-91) and 78' 1/2 ton axles.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 04-10-2010, 04:51 PM   #6
WyoRoadDog
Page intentionally left blank.
WyoRoadDog's Avatar
If you're doing the FGB52 kit, you're changing the springs on the front, correct? If so, then you can put whatever springs you want on there. The only thing to watch there would be the matching the spring perches on the axle, but I don't think that is an issue, I used lift springs for a 69-72 on the front with no problems.
The rear is where the real difference is, the springs are a different width and pin location, at least on the '67, and I think most '68's as well. If you're dealing with Kert at DIY4X already, he'll customize any of his stuff for you. He modified the shackle flip I put on the rear of my '67 without any hesitation.
Hope this helps.
-Finding my notes, here's what I have as measurements from my '67:
Front springs 3" wide at eyes, 2 1/2" at spring perch, 44" eye to eye.
Rear springs 3" wide at eyes, 2 1/2 at spring perch, 56" eye to eye, CENTER pin.
There is a theory which states that if ever anyone discovers exactly what the Universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.There is another theory which states that this has already happened. - Douglas Adams
'67 GMC 4x4, 305 V6! Or all the parts for anyway...
'17 Subaru Outback.
'18 Toyota Tacoma TRD Off Road.
'99 Ducati 900SS.
WyoRoadDog is offline   Reply With Quote
Old 04-13-2010, 05:23 PM   #7
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Frame is the same expect it is not dimpled for p/s most likely. I did the FGB52 kit on my 68 suburban.
link to build thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=312252
68SWB4x4 is offline   Reply With Quote
Old 04-13-2010, 05:39 PM   #8
Mr-Jack
Beer Drink'n Knuckle Dragger
Mr-Jack's Avatar
Hope this helps.
what had to be modified on your shackle flip?
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US
- 67 GMC Long-Wide 350/SM420
My BACON Wrapped Meatloaf Recipe
Mr-Jack is offline   Reply With Quote
Old 04-13-2010, 10:31 PM   #9
WyoRoadDog
WyoRoadDog's Avatar
The stock springs on the '67 are wider than the 69-72, so I had Kert make the shackle wider to accommodate them, and he welded on a spacer to the other side to match his bracket. Easier than having the bracket made a custom width.
'17 Subaru Outback.
'99 Ducati 900SS.
Old 04-13-2010, 10:58 PM   #10
Mr-Jack
Mr-Jack's Avatar
gotcha...i went a little differant route with my planning, but it all works out the same
