Under bed what fuel line?
What are you guys who have moved the tank under the bed doing for fuel lines? Hard line? Braided steel line? I would like to see pics if ya got 'em.
Senior Enthusiast
Re: Under bed what fuel line?
I'm running 3/8" steel hard line on mine. I got two of the longest pieces available and joined them together with a double female inverted flare fitting. Unfortunately I don't have any photos of the passenger inside frame rail where it runs.
If you go with hard line, my personal opinion is to avoid the new green or black hand formable tubing. I stick with the old silver hard line which is still available at some of the independent parts stores. Using expensive English roller tubing benders, the green/black stuff is the only tubing I've ever had kink and fold over in many decades of forming tubing.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 04-30-2010 at 10:24 PM. |
i always aneal them with a gas enriched acetyling torch, they will not crimp, its softens the metal just enough, also great for reflaring them, are you going to run a return line back to the tank...?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Good stuff Markeb & Rich. Thanks for sharing those nuggets.
I used Galvanized Zinc Fuel Line from Jegs. It is already annealed and is really easy to work with.
http://www.jegs.com/i/JEGS/555/63036/10002/-1 The Original Heavy Duty-Plated TubingWith the bed off my truck I was able to run one line from the tank all the way to the fuel pump. Also, I used AN fittings for the end connections, just 'cause I have a Rigid AN Flaring tool.Heavy duty original equipment type double wall copperized steel tubing which is coated in galvanized zinc for superior rust protection.Heavy Duty-Plated tubing w/Chip Resistant Powder CoatingThe same construction as the original plus features our durable gloss black or silver powder coating that resists cracking or chipping in the fabrication process for long life and years of service. For the professional touch!Each kit includes 25' of tubing and an assortment of standard inverted flare fittings for domestic vehicle applications. Last edited by lakeroadster; 05-01-2010 at 07:42 AM. |
Good info John, the tubing sounds much like Cunifer http://store.fedhillusa.com/?gclid=C...FRYiagodcDcO0A
which would make life easier if you didnot have a torch, I`m still considering the use of your tank, just haven`t committed yet, I`m surpprised you didnot run a return line back to the tank. in any case really nice job ![]()
Bob Drake has 49-52 Chevy tanks on sale now for $131.25 (their P/N C4952-9200) but I am unsure as to if it has a bolt on filler neck or a stock welded one. Not sure the welded on one would work.
And I didn't run a return line to the tank 'casue I don't need one with a carb. |
I guess I'm old school with brake lines. I use two lenghts of steel brake line for the under bed long line.
Bob |
"Where were you in '62?"
![]() Join Date: Jul 2004
Check out my build thread.
I thinking about changing it, but it can give you an idea.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
