Old 02-03-2010, 10:34 PM   #76
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
Re: New engine, won't run!
Exhaust currently is open headers.
The ignition system is a known good one. It came right off the motor that came out of the truck. That motor ran until i took it out and put the new one in.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 02-04-2010, 04:21 AM   #77
combustion
do you have compression? does it sound like it cranks over loose? did you install the spark plugs wires counting clockwise or counterclockwise on the distributor? try adding fuel directly into the manifold to eliminate it being the issue. do all chevy engines spin the distributors the same way? are your points fully breaking and closing properly? is your module jacked up if you are running hei? cant be that many things
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 02-04-2010, 01:23 PM   #78
brothers69c-10
Suburban Hick
Sounds like someone needs to read through other posts before posting their 2 cents worth.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 02-04-2010, 02:51 PM   #79
D13
D13's Avatar
OK, Here's my confession and something to check.
Check that the plug wires are in firing order going the correct way around the cap. Set it to #1, remove the cap, roate 1/4 turn, and see what plug wire the rotor is pointing to. Then make sure that matches the firing order.
I've sequenced the the entire distributor backwards before. It would hit on #1 and sort of on a couple others but would not run. The more fuel the worst problem as the plugs got a bath.
Compresson check? Rockers adjusted and not holding the valves open (ie lifters pumped up)? Suck squeeze bang blow - need valves for 3 of the 4.
Or, fuel, air, and spark. Ether should have taken care of the fuel unless the carb is dumping fuel down the intake.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-04-2010, 07:00 PM   #80
russgt
russgt's Avatar
Any signs of gas in your oil? After cranking it for a little while do you notice gas coming out of the collectors?
russgt is offline   Reply With Quote
Old 02-08-2010, 04:11 AM   #81
combustion
if you had compression, right firing order, fuel, cam timing and ign timing right i bet you it would run. you are obviously missing one of them. no pun intended.
Old 03-09-2010, 12:13 PM   #82
britnjc
britnjc's Avatar
any updates?
britnjc is offline   Reply With Quote
Old 03-09-2010, 05:51 PM   #83
leegrady
Compression
Spark at the right time
Fuel
With these you are well on your way.
My two cents is: the base timing is off, and possibly no or low compression in one or more cylinders.
Set #1 at tdc of the compression stroke. Crank the engine over with #1 spark plug out, and your finger over the hole, and stop cranking when you feel air being push out. Now your in the ball park turn the crank manually until the mark on the harmonic balancer points right at zero ("0") degrees on the scale. (Remember that the crankshaft to camshaft ratio is: 2:1, so that mark will also point at the scale 180 opposite the compression stroke.) So, again, #1 at tdc compression stroke, both intake and exhaust valves closed, and next be sure the rotor in the distributor is pointed at #1 spark plug wire. If I'm not mistaken that distributor shaft will only go two ways: correct, and 180 degrees off. You don't need to remove the timing cover to know the sprockets are installed correctly.
If I found a no, or low compression cylinder I'd perform a cylinder leak down test to determine if the lack of compression is caused by an intake valve not seating properly, or an exhaust valve not seating, or if the rings are not holding. You simply pump (low psi) compressed air into the cylinder by way of the spark plug hole, and listen for the tall tale hiss of air. Listen down the carb for intake, yep, the exhaust pipe for, you guess it, an exhaust valve that is not closed when it should be, and finally remove the oil filler cap on the valve cover and hear what you've been missing. A hiss here says: rings. Oh, yeah, this must be done with all the valves on the cylinder you're testing be on the flat of the cam, (closed) compression stroke of that cylinder.
I hope compression is not your problem. I want to write too not to be confused by ole wife's tales. Your problem will be obvious once you find it. On a personal note: that ole big block will at least run rough even if there is oil, wd-40, low octane gas, moose piss and beer contamination in the cylinders. Cold weather be damned. I get in my truck 81 GMC K2500 on some mornings up here in 25 degrees below zero, not wind chill factor, and it fires right up no problem. Sep' my coffee turns to slush before I open the door.
No, your problem is there, and you'll probably go, "of course!".
leegrady is offline   Reply With Quote
Old 03-09-2010, 10:56 PM   #84
Drzronnie
I know nothing about this motor so this is a stab in the dark from my Mercedes background. Mercedes will often have starting problems all the way up to a no start due to horribly out of adjustment valves (recommended service ever 10K but I picked up a 76 300D that had never had it done, and the people were told it needed a motor). I know somebody had mentioned this earlier but I just thought I would throw in how bad the benz problem is thinking maybe it could be on this too. Hey man good luck, hope ya get it runnin'.
82 C60
82 C20 (neverending project)
77 Mercedes 300D (gets me to work)
Drzronnie is offline   Reply With Quote
Old 03-10-2010, 03:03 PM   #85
PRattenbury
Check your wiring to your starter? Run vs Start terminal? Get those mixed up it may fire in the start position but stop when key is released to run position.
PRattenbury is offline   Reply With Quote
Old 03-14-2010, 10:55 PM   #86
LeaveEmBehind
this may sound stupid but may play a part. Does it crank over fast enough? ive had a few motors refuse to start because it didnt crank fast enough. Used to have to crank it at WOT to get it to run if not it would just spit n sputter, till 1 day it just refused to start ended up getting a high-performance starter (just spun faster) n solved my problem. i dont know why it needed to crank fast but did, had fine compression (190) fuel was fine and spark was fine, but stupid as it sounds that what it was, so if your compression is good and u feel timing is fine, maybe try cranking at wot or if it dont help maybe a better starter? Keep us posted as im very curious as is others to what your problem is.
LeaveEmBehind is offline   Reply With Quote
Old 03-24-2010, 11:03 AM   #87
brothers69c-10
Suburban Hick
Well to all of you wondering, i think i finally solved the problem. I poured oil down the cylinders 2 weeks ago and let it sit for about a week and went back, cranked the motor over for a while and left the plugs out for a few hours, the nput them back in and the stupid thing acutally fired on all 8 for about 5 seconds. Didn't backfire or nothing. So i pulled the plugs and they were all covered in oil and some wd40 that had been sprayed down the cylinders about 3 months ago prior to installing the engine. In other words there is som much oil residue in the cylinders that its causing the plugs to foul and lose spark, get the cylinders cleaned out and i think i will be in good shape.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 03-24-2010, 11:29 AM   #88
68 TT
Still plays with trucks
68 TT's Avatar
Good to hear it fired up. If they are just oil fouled you can soak the plugs in mineral spirits to wash off the oil so they are usable again without having to replace them. Blow them dry with compressed air and you are good to go.
It should burn any excess oil out of the cylinders pretty quickly once clean plugs are in there.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 03-25-2010, 09:26 PM   #89
brothers69c-10
Suburban Hick
Going out early in the morning to clean the plugs and try ro clean the cylinders out some more and see what happens
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 03-29-2010, 12:35 AM   #90
brothers69c-10
Suburban Hick
So cleaned up two sets of plugs and finally got it to where when ipull the plugs out now they actually smell like gas, but the darn thing still won't run. Might buy a third set of plugs, maybe the other ones were fouled one too many times? It will fire and act like it wants to take off, but just won't. On a side note i know the valves aren't too losse cause the motor turns over nice and smoothe, but there is a possibility of thembeing too tight(keeping a valve opened.) I was going to do a compression test, but i was doig something wrong and lost a sring for one ofthe release valves on the tester(sorry ryan), but with using my finger i checked each cylinder on the drivers side and they felt consistent. Going to get accurate compression readings hopefully this coming wekend and go from there cause i really want to drive this thing.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 03-29-2010, 08:52 AM   #91
ont_guy_38
ont_guy_38's Avatar
The plugs they make today don't like to be cleaned , they always seem to foul after that . I would try another new set
ont_guy_38 is offline   Reply With Quote
Old 04-05-2010, 01:18 PM   #92
brothers69c-10
Suburban Hick
Ok so I've tried new spark plugs, rechecked the valves and adjusted the mtighter and looser to see if that did anything, Pulled the valve covers off and checked the valves to make sure the cam was in right, tried different carburators, pouring gas down the carb, differnt distributor cap again, checked timing again, has compression. At this point if i had the money i would just put a cummins in the old truck
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 04-05-2010, 01:20 PM   #93
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
But you still haven't pulled the timing cover to check the alignment of the sprockets, correct?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-05-2010, 03:27 PM   #94
brothers69c-10
Suburban Hick
Shouldn't have to, pulled the valve covers, broguht number one cylinder up to top dead center and both valves on #1 and 6 were closed and the distributor was in the correct position.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 04-05-2010, 03:31 PM   #95
glock35ipsc
Oooooooook.
Bob
Old 05-04-2010, 03:56 PM   #96
brothers69c-10
Suburban Hick
Well i give up, I'm just going to pull the engine out, put new rings in it, a different cam and start all over. Also i'm going to build a stand to test fire it on so i don't have to put it back in the truck to see if it runs.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 05-04-2010, 05:00 PM   #97
Mayhem.Evol
Well, goodluck with it man. keep us updated on it!
Mayhem.Evol is offline   Reply With Quote
Old 05-04-2010, 05:42 PM   #98
billnorman
Let me say this about that. I see by your list of other vehicles that you should have enough experience with old iron to get this thing running. When I was young, and I'm not, I would try and try and try and sometimes give up and get some old fart to help me. It always worked. I'd either have to repair something or get the verdict; "It's kaput and isn't gonna go", and give up. Wish I was your neighbor, I'd be over with a cold one just to accept the challenge of getting it going, but I'm not. I would bet some old fart that has been turning wrenches for 50 years can give you the verdict, or get it going, but at this point, you might as well forget it. Let us know what you find.
billnorman is offline   Reply With Quote
Old 05-10-2010, 06:15 PM   #99
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
He has had a few of the said old farts giving ideas and nothing is working. We/he have tried everything. I think the rings are just rusted or glazed from the engine sitting so dang long. This is my guess. we will try the new rings and install a cam that will fit his needs more accordingly and go from there.
Ryan
1969 Chevy milk truck
Old 11-28-2010, 11:56 AM   #100
brothers69c-10
Suburban Hick
To anybody still wondering, i finally got this engine running. I pulled it out and cleaned everything up. I installed all new bearings, rings, and a new hydraulic cam. I did all this within the last week and put the motor in yesterday and it fired right up for me. When i tore the engine down it had alot of sludge built up in it. The lubriplate that was used o asse,ble the motor had broken down. The cam didn't look bad, but i favor a hydraulic cam over a solid lifter one.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
