Old 05-24-2010, 06:56 AM   #1
jht3rd
ls swap engine mounts ?
Buying things for my upcoming ls swap. What engine mount adapters did you use? I want to use the truck manifolds and have room for the AC Compressor without to much trouble. I like Ece's but if I could get a forty dollar set off ebay that would be great! I know it would be cheaper to make them, but dont have the equipment for that.
jht3rd is offline   Reply With Quote
Old 05-24-2010, 11:21 AM   #2
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
Re: ls swap engine mounts ?
Interested in knowing the magic combo also! If I remember correctly, the ECE mounts and POL frame mounts are the setup to use, but I am not 100% sure. I'm sure someone else knows...
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline   Reply With Quote
Old 05-24-2010, 01:22 PM   #3
Clyde65
Clyde65's Avatar
1st of all, you wont be able to use the LSx compressor unless you are planning on cutting the frame some. You can use Kwickperformances high mount for a Sanden compressor.
Mounts: If it were me, I would spend the $ on ECE mounts, from what I understand you can use stock Trailblazer SS manifolds with them, otherwise you will need to use POL (http://www.performanceonline.com/sto...cat=455&page=1) mounts, this is what I used, they work really well putting the motor up about 1" so headers will fit, but the stock manifolds wont and fbody mounts wont either. Hope this helps.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-24-2010, 01:44 PM   #4
Ackattack
Ackattack's Avatar
I used the POL stand/mounts and then made my own adapter plates to go from the sbc 3 bolts to the genIII 4 bolt patern
Ackattack is offline   Reply With Quote
Old 05-24-2010, 02:16 PM   #5
68 short step
Originally Posted by Clyde65 View Post
1st of all, you wont be able to use the LSx compressor unless you are planning on cutting the frame some. .
not true, ive done a few of these swaps useing the POL setup, and i run the stock compressor everytime...
68 short step is offline   Reply With Quote
Old 05-24-2010, 03:44 PM   #6
Clyde65
Clyde65's Avatar
maybe 68, I did have to cut mine on my 65 though,
Clyde65
Rebuild of Clyde
support our troops!
Old 05-24-2010, 04:27 PM   #7
killer71
killer71's Avatar
didn't have to cut the 71 either.
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 05-25-2010, 10:46 AM   #8
joejbal
joejbal's Avatar
The pol mounts move the motor forward and up. I tried to keep my motor in the stock 6 cyl location for balance, but the pol mounts put the motor a d trans up too high, the 4l60e hits the tunnel.
I am using stock frame pads and prothane versions of the 6 cyl mounts, with cheap steel adapter plates from summit.
Joe
joejbal is offline   Reply With Quote
Old 05-25-2010, 01:13 PM   #9
jht3rd
I would like to run the 4l60e also. Is the ece kit complete or do you still have to order the adapters like with the pol setup?
Old 05-25-2010, 01:50 PM   #10
Ackattack
Ackattack's Avatar
I ended up using a high hump tranny cover with mine. I'm not 100% sure if I would have had to. When I set my cab on, the tranny was hitting the low tranny hump area, so I cut it out, then I realized the drive shaft was also hitting the cab, so I ended up moving the tail of the transmission down.
Old 05-25-2010, 02:16 PM   #11
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
ECE kit is complete...I think (well, minus the LSx mounting bolts). Its what I bought for my swap.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
