Old 05-26-2010, 09:42 PM   #26
truckdude239
truckdude239's Avatar
Re: Axle and wheel fell out of Dana 60
i may be wrong btw i'm not use tot eh dand 60s but that axle doesn't look right i'm use tot the style in the youtube vid
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-26-2010, 09:45 PM   #27
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
Might be fixable... if I was closer I would try to talk you out of it!
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline   Reply With Quote
Old 05-27-2010, 01:19 AM   #28
Racinaround
Racinaround's Avatar
I have seen that before!
Call Randys Ring & Pinion and get a Axle, Brearing and Retailer plate!
They can press it together and ship to you!
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
Old 05-27-2010, 01:28 AM   #29
71chevytruckguy
71chevytruckguy's Avatar
Wheel bearing went out, letting the axle come out. I've had the same thing happen several times in the dana 35's I've had in my jeep. Put a new wheel bearing in it and you should be good to go. Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 05-30-2010, 05:23 AM   #30
raycow
First, unbolt the retainer and pull the bearing and seal out of the housing. You will probably need them for samples because I don't think a normal parts store is going to have a listing for that rear. Hopefully, the bearing and seal will have numbers on them.
Then take the wheel and drum off the shaft and see if there is any shop that wants to press a new bearing onto it. My gut feeling is that you are going to need a new shaft.
Ray
raycow is offline   Reply With Quote
