05-24-2010, 09:14 PM | #1 |
Junior Member
Axle and wheel fell out of Dana 60
What is your guess on how bad off it is? This is on my 69 1/2 ton coil sprung truck.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 05-24-2010 at 09:15 PM. |
05-24-2010, 09:25 PM | #2 |
Re: Axel and wheel fell out of Dana 60
Probably broke the tip of the axle off where the c clip goes. Probably not good for the internals.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
05-24-2010, 09:27 PM | #3 |
Junior Member
I for got to mention the axel/wheel area was smoking like crazy and the azel is scored badly near the end closest the wheel.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
05-24-2010, 09:35 PM | #4 |
Did you catch the wheel? LOL U got any pics of it, did it snap the axle right at wheel?
05-24-2010, 09:56 PM | #5 |
Factory Strippers Rule!
These aren't C-clip axles, so I am ASSuming the retainer bearing cooked.
If you want, I will gladly come by and get rid of that "problem" axle for you, free of charge!
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
05-24-2010, 10:38 PM | #6 |
Restoring it $200 at a time...
Been there, done that. The ear on the lock washer sheared off and allowed the retainer nut to back off. The axle and wheel walked out about 10" in a low-speed corner. The wife said she'd never seen me turn that white before.
The only damage was to the threads on the end of the axle tube. Took awhile to find someone with an adjustable die that big. With your smoke and the scoring, I'd second the failed bearing diagnosis.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 Last edited by hounddogs!; 05-24-2010 at 10:40 PM. |
05-25-2010, 12:05 AM | #7 |
Junior Member
It came apart in the middle near the gears while I was towing the truck so no damage to the truck. We slid the axel and wheel back on after we jacked the truck up then winched it on a trailer. I have another 6 lug rear but wondered how much it might cost to fix this rear end or how much could the rearend be worth in this condition?
05-25-2010, 12:54 AM | #8 |
You may not be in too much trouble as long as any bearing surfaces have not been scored. On a 67 Dodge 3/4 ton with a heavy duty rear I once had one or more bent ears on a retaining ring fail and the axle assembly just unscrewed going around a corner - knew nothing until I lost push while turning and happened to look in the side view mirror and saw the wheel/tire out about 12 inches from the truck and a very bendy axle shaft still running into the housing. Managed to steer the other direction and the wheel/axle moved back almost into place. Stopped, jacked er up, screwed everything back into place as best I could on the spot, put the retaining ring back in place and locked by bending a couple of the remaining ears.
Next day got a new ring, took it all apart to check everything, found no visible damage to bearing or shaft surfaces, put it all together correctly and installed the new lock ring - then drove the truck another 50,000 mi. with no issues. Carefully check the bearing surfaces before you proceed with any fixes.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
05-25-2010, 09:10 AM | #9 |
Trying to learn something. How are these not C-clip axles?
05-25-2010, 10:04 AM | #10 | |
Ray Last edited by raycow; 05-25-2010 at 10:08 AM. |
05-25-2010, 10:19 AM | #11 |
Re: Axle and wheel fell out of Dana 60
Guess I should pay more attention to the thread title! LOL
05-25-2010, 10:42 AM | #12 |
Junior Member
There are a few out there. I think they may have been special order. Someone else is looking for one for a half ton in the parts for sale section. I will try to post some pics of the damage to the axel this evening.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 05-25-2010 at 10:42 AM. Reason: add info |
05-25-2010, 11:33 AM | #13 | |
Java Mechanic
I have a 68 C-20 with a 350 and a HO72 rear. I don't think you'll find a build sheet listing that particular combo. lol
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
05-25-2010, 12:06 PM | #14 |
Hounddog and CCCC, you are talking about full-floating 3/4 ton rear axles and BB72Chevy has a 6 lug, 1/2 ton axle. In all likelyhood if it isn't a 12 bolt, Gm Corporate, then it could be a DANA 44.
Without a picture does it look like one of these. http://coloradok5.com/axleguide.shtml As raycow said, the only DANA 60's that aren't full-floating are in late 60's Mopars. They were used only with 440 and 426 HEMI's and even then, only if they had 4 speeds. |
05-25-2010, 12:14 PM | #15 |
Junior Member
The truck is about as original as it gets even has the original 165k mi motor. I was told it was a Dana 60 by the rear end shop I had service the rearend when I purchased the truck. It was also almost impossible to find a replacement carrier bearing because it was a Dana 60 rearend so I went to a one piece driveshaft.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 05-25-2010 at 01:34 PM. Reason: add info |
05-25-2010, 01:06 PM | #16 | |
05-25-2010, 01:36 PM | #17 |
Easy enough to check. It has a "60" cast right into the housing. The top of the "6" is normally almost closed off but it looks like mine has been struck at some time. The second picture is from the web and shows one that doesn't have a leaking gasket like mine. ggg
05-25-2010, 01:47 PM | #18 |
A little more off topic but while I was searching for a HO72 with 5.14's ( needle in a hay stack those 5.14's ) I stumbled across a 1970 and a I think a 71 bolth with dana 60 FF. The trucks were in the normall condition and one was missing a shaft but other wise in good shape.
I spotted them thinking they would have a HO axle and they truned out to be 60's. Any idea what there worth or are they even worth the effort? Jason. |
05-25-2010, 05:46 PM | #19 | |
Devil's in the Details
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
05-25-2010, 08:09 PM | #20 |
Junior Member
Here are some pics of what it looks like and proof that it is indeed a Dana 60 from the factory.
05-25-2010, 08:59 PM | #21 | |
Jason m. |
05-26-2010, 02:56 AM | #22 |
Location: Aurora,Il ..born,raised and still live in the same house
damm dude, that is some scary stuff!
wonder if this is any help? |
05-26-2010, 06:32 AM | #23 |
I had that happen on a 79 CJ5. May have been a Dana 60, not sure though. The reason why my axel came out though was because the previous owner replaced the bearings but never had the bearing retainers pressed back on.
I was doing about 50mph when I felt the right rear drop down. I came real close to rolling the damn thing. lol The weird thing was, when I finally got it stopped in somones front yard, the tire was back under the wheel well and the axel was laying on the leaf spring. I was really lucky.
http://67-72chevytrucks.com/vboard/s...d.php?t=355153 |
05-26-2010, 08:03 PM | #24 |
Junior Member
Does any have a guess now that we have pics?
05-26-2010, 09:17 PM | #25 |
well that rear end is trash there is a metteel piece that sticks out and the lock rings and bearing screw too that looks like it got riped off, unless you can find that out plate with ti an a new axle i'd say its not worth fixing
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 05-26-2010 at 09:17 PM. |
