Old 05-28-2010, 02:21 PM   #1
amdriver
Failure
Every time I start my truck a buzzer-sound goes off and "failure" reads across my radio. Does anyone know what is gong on? Is it the radio or the truck?
amdriver is offline   Reply With Quote
Old 05-28-2010, 02:23 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Failure
I'm unaware of any 73-87 chevy truck that has a radio with a display that reads anything. Since you mentioned no year model, but posted in this forum, that's the information I have to go off of.
Like my mechanic always says, "could not duplicate problem".
RandyP is offline   Reply With Quote
Old 05-28-2010, 02:26 PM   #3
amdriver
Re: Failure
It's a 76. I put a different radio in that has a face that reads the station, artist, stuff like that. Does that help at all?
Old 05-28-2010, 02:35 PM   #4
WigglesTheHoly
IT Guy/ Father/ Chevy lover
WigglesTheHoly's Avatar
Re: Failure
radio the truck doesn't interface with the radio only supplies power
78 Chevy (Pictures) SOLD
79 Chevy LWB (pasture)
83 Chevy LWB (crushed rusted beyond repair)
02 TrailBlazer SOLD
03 VW Passat wagonSOLD
95 extended cab silveradoSOLD (still in family)
05 Crew Cab Silverado 5.3 (The Turd)
WTB: 66 El camino
Technology Specialist aspiring to be a gear head.
WigglesTheHoly is offline   Reply With Quote
Old 05-28-2010, 03:05 PM   #5
amdriver
Re: Failure
Okay then it must be the truck. Why would the truck make the buzzer sound?
Old 05-28-2010, 03:19 PM   #6
RandyP
RandyP's Avatar
Re: Failure
Is the buzzer coming over the speakers, or from under the dash?
Old 05-28-2010, 03:48 PM   #7
WigglesTheHoly
Re: Failure
IF it doesn't come from the speakers there is a possibility you are arcing power from a poor connection or broken wire
02 TrailBlazer SOLD
WTB: 66 El camino
Old 05-28-2010, 07:08 PM   #8
amdriver
Re: Failure
I have no idea why it would make the sound. Everything looks good. The sound is definitely coming from under the dash. I will check for connections and broken wires. Thanks guys!
Old 05-28-2010, 08:03 PM   #9
Averix
Re: Failure
If the sound is coming from the deck itself, and the screen reads 'failure' or 'protect' it's generally a sign of a shorted final in the deck. Usually this is caused by one of the speaker leads touching ground (assuming this isnt a common ground unit, but not much info to go off of so I'm just throwing common problems out there) or the deck has malfunctioned.
When trouble shooting this... it is usually best to disconnect all the speakers and antenna from the deck itself and turn it on and see if it's still coming up. If that solves the problem, its most likely a speaker issue (assuming your not running amps) if it still comes up fault, I'd personally think the problem lies in the radio itself.
Averix is offline   Reply With Quote
Old 05-28-2010, 10:08 PM   #10
Goldfinger
Goldfinger's Avatar
Re: Failure
their is always a buzzer when you turn the key it tells you that power is turned on. the radio has nothing to do with the truck it may be malfunctioning. if the buzzer is over the speaker the wires are touching each other
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 05-28-2010, 10:39 PM   #11
redneckchevy
redneckchevy's Avatar
Re: Failure
I dont know if a 76 would have it, but you sure it's not the seat belt buzzer?
redneckchevy is offline   Reply With Quote
Old 05-29-2010, 11:21 AM   #12
westofb
I really hate wet sanding!
westofb's Avatar
Re: Failure
I got a 75 that is quiet as a church mouse, well, until they BBC fires up....LOL! Seriously, kill power to the radio and see if that kills the buzzer, mine has no buzzer.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 05-29-2010, 10:23 PM   #13
amdriver
Re: Failure
Awesome. Thanks for the help!
