700r4 leaking from yoke while jacked up or on a hill
i jus had my engine pulled and while the tans was jacked up it leaked out a bunch of trans fluid. the guy told me that it was leaking out of the yoke. he also told me that it wouldn't be a problem to just plug the hole in th yoke to keep it from leaking. anyone had this problem.
Garage wrench
Re: 700r4 leaking from yoke while jacked up or on a hill
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
Thanks for the info. Mines a 400turbo but I've noticed when i have mine parked in the drive way ( whice is a pertty good hill) there would be trans fluid on the ground when i moved it. I'll check into the o'ring.
85 Chevy C-10 383 stroker |
thanks a lot
.. !WAR FEDOR! ..
[QUOTE=SBTork;4015407]DO NOT PLUG THE HOLE!!!
Do this instead....http://73-87.com/7387garage/drivetrain/yokeleak.htm[/ just out of curiousity, why not?
"san diego chargers #1" |
Most trannies that have been rebuilt no longer have that sleeve. Millions of trannies dont have the hole in yoke at all. I vote tack weld the hole shut and call it a day.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
gets board easy.......
i plug the hole with Silicone, works everytime
Plugged mine about 2 years ago. No problems since.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch |
what about a th350? mine does the same thing if i park in the driveway or leave it sitting for a while.
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
#12 | |
Insert Witty Text Here
Before that, I had just sprayed the hole with brake cleaner to clean it up and dabbed some RTV on it with the tip of a screwdriver. That worked, but it had to be replaced once a year or so. I eventually had to buy a new yoke from a drivetrain shop. They sold me one with no hole, and said they weld up EVERY one they work on. Slonaker |
Its the same setup in a th350. Just plug the hole. A lot of yokes didnt even have the hole in the first place.
#14 | |
Garage wrench
[quote=joe1982;4017633]
I could have sworn that I remember reading somewhere that the hold is needed for something but I cannot remember what. Obviously it is not needed for anything according to others, it would be cheaper and just as effective to just weld it up, so go for it.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
