Old 06-29-2010, 11:20 AM   #1
masaki
some help with my jimmy transmission...
Hi, I want some help with my jimmy tranny, I want to confirm the trasmission parts models in my jimmy, here are some pics:
please correct me if I'm wrong
Dana44
NP205
SM426
Umknown rear axle
The rear axle, is not the original, can somebody identify this part?, wich axle I need to buy in order to use the 4x4 option in my jimmy?
PS:
in other way, what mean married or divorcied transmission...=?
1988 Ford taurus LX SW
V6 3.0L vulcan - Axod
1973 GMC Jimmy Sierra 4x4
L6 diesel nissan LD28 (temporal engine)
masaki is offline   Reply With Quote
Old 06-29-2010, 03:45 PM   #2
Redcap
Re: some help with my jimmy transmission...
That rear axle looks like a earlier Ford 9" or possibly a Mopar 8.75".
Your transmission should be a SM465 and your transfer case is indeed a NP205.
Married transfercases mean it attaches via adapter directly to the transmission. Divorced means there would be a short driveshaft between the output yoke on the transmission and the input yoke on the transfercase. A married setup is stronger.
Redcap is offline   Reply With Quote
Old 06-29-2010, 04:53 PM   #3
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Isn't that the muncie SM465?
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 06-29-2010, 04:57 PM   #4
Redcap
Yup, sure is. I had too many things going and typed the wrong thing.
Old 06-29-2010, 07:10 PM   #5
raycow
Of US rears, Mopar, Olds/Pontiac (till 64), and Ford (till 56) had round center sections and no removable cover. I think maybe Cadillac and Packard too. All except the Mopar are too scarce to consider seriously.
However, considering where the OP is located, I think he is more likely looking at a Nissan or Toyota rear.
Ray
raycow is offline   Reply With Quote
Old 07-04-2010, 07:57 PM   #6
masaki
Hi thanks for the reply! here you can see more shots of the rear axle, somebody can identify this axle? in other way, what axle I need to find to replace this? remember I want to use the 4x4 option of the truck...
Masaki
Old 07-04-2010, 08:21 PM   #7
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
is that an eaton HO52?
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 07-04-2010, 11:02 PM   #8
Davetopay
Nope. If it was an HO52 the center would have a cover held on with bolts.
Doubt it is a Toyota rear with that much width and beef. Also, if it had come from a Land Cruiser it would have a passenger side offset to the pumpkin and a bolt on cover similar to the Eaton.
Nissan Patrol could be a real possibilty. Not likely to be a rover though.
Davetopay is offline   Reply With Quote
Old 07-04-2010, 11:06 PM   #9
bglad420
bglad420's Avatar
Did you drag that out of three feet of dirt?
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50.
bglad420 is offline   Reply With Quote
Old 07-04-2010, 11:11 PM   #10
Davetopay
The more I look at it, the more it looks like an old Mopar 8.75 axle.
The snout on the center section, the welds and the fill plug look Mopar to me.
Old 07-05-2010, 05:27 PM   #11
raycow
I agree, it does look like a Mopar, but I just wasn't expecting to see one in Peru. The Nissan or Toyota rears I was thinking about are from the 2WD trucks, not 4WD. They have round welded covers.
How about giving us a little bit of help, like what is the wheel bolt pattern? Or maybe just a pic of the axle end with the hubcap off?
Ray
Old 07-06-2010, 05:57 AM   #12
Blazer1970
Blazer1970's Avatar
What lug pattern is on those axles? I suspect that front and rear both came from a different truck. Probably a Dodge. Is it five lug?
Blazer1970 is offline   Reply With Quote
