07-08-2010, 06:40 PM | #26 |
Re: Just twisted off an intake manifold bolt!!!
Great point, I just replaced the PCV for that exact reason but was still leaking oil.
I am going to have to do the job tomorrow, started the engine today just to observe how bad the leak would be and it is totally sealed up. For now. If I run it that way I gather that i could lose the engine or warp the manifold. The black Permutex worked on sealing off the oil though but I am going to get the oats stuff that was recommended. |
07-08-2010, 07:08 PM | #27 |
yes, i do
well did you let her run until she was warm?? cause that's when everything expands and when you will find your leaks. check the oil and see if it's milky
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
07-08-2010, 09:02 PM | #28 |
Ran it only for about 3 minutes.
07-08-2010, 09:34 PM | #29 |
Just brought the truck up to full temp, 90 outside as well. Ran it for 20 minutes, multiple revs - no leaks. Oh well, it doesn't really qualify under the - "if it ain't broke don't fix it rule" because it can apparently go at any time and knowing Murphy's law, it would be a bad time. Plus, the bolt is broken. =) I had a feeling it would hold, I just don't know for how long.
07-08-2010, 09:40 PM | #30 |
yes, i do
again does the oil look milky?
07-08-2010, 10:08 PM | #31 |
Nope, no oil in the water or water in the oil.
07-09-2010, 09:16 PM | #32 |
Well, started the job today. Will be asking questions I'm sure.
07-10-2010, 12:11 AM | #33 |
I see no one mentioned not to use the cheap gaskets that come in the kit for the ends of the manifold. Use a good silicone instead. Those gaskets tend to leak oil after a while. Don't know if you knew this or not, but if you did a friendly reminder can't hurt.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
07-10-2010, 07:14 AM | #34 |
I would check all your bolts once you remove the intake. There had to be a reason why the bolt snapped off and it was probably due to it being too long and bottoming out. If the intake was off previously, the wrong length replacement bolts could very well have been used. I have never had to use sealant on intake manifold bolts. Good luck on removing it. Patience is the key along with many applications of good penetrant over time. If you force it, it may twist off again flush leading to a drill out/tap cleanup as your last option. You are going to have to be super careful about any metal filings getting into the engine as you work on it with the head still on the motor.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
07-11-2010, 09:47 AM | #35 |
Okay, this one is going to sound silly, but I swear it has worked for me more than once. Take a rag or paper towel and twist it in the hole. She may back right out!
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
07-11-2010, 10:10 AM | #36 | |
To the OP. Now that the head is broken off the torque is released off the bolt. It may come out easily once the intake is off. I would replace all the intake bolts. It is possible that that intake bolts were over torqued by a PO causing it to fail. If one was over torqued chances are good they all were.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 07-11-2010 at 10:13 AM. |
07-11-2010, 10:17 AM | #37 | |
Still plays with trucks
Make sure you use a die grinder with a ball end carbide cutter on the head of the broken off bolt. The irregular surface will damage your drill bit and/or make it walk to the side damaging the intake. Make sure you are drilling perfectly parallel with the center line of the bolt with the left hand drill bit or it will break the drill bit when the bolt starts to come out. A 1/4" left hand drill bit will work well on the 3/8" intake bolts. If you have a hammer drill use it. The shock will help break the fastener loose.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
