Old 08-03-2010, 02:35 AM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Anyone using stock LS clutch fan?
Will the stock LS fan fit in the original truck fan shroud? Or will the motor set too far back or forward? I am waiting on headers and oil pan in order to drop mine in. Hopefully in the next few days if Doug Thorley headers show up. Just wanting to know if I need to order a new rad/fan combo.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 08-03-2010, 09:35 AM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Anyone using stock LS clutch fan?
I am using one on my 5.3, along with the truck's original shroud and radiator, and with the adapter plates I used it sits the fan perfectly in the shroud.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-03-2010, 12:01 PM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Ah, yes I can see. Looks good!! And cheaper than buying a new rad/fan.
Old 08-03-2010, 05:14 PM   #4
Ackattack
Ackattack's Avatar
I got a set of electric fans for a LS1 F-body for $50. Fits the truck radiator just about perfect.
Ackattack is offline   Reply With Quote
Old 08-03-2010, 09:55 PM   #5
Jim_PA
If you are using ECE mounting hardware, I highly doubt any sort of mechanical fan would fit:
I'm using the Entropy rad/fans and ECE mounts. It is the downside to the ECE setup, but I wanted an easy to install secure setup, so it is what it is!
Jim_PA is offline   Reply With Quote
Old 08-03-2010, 11:14 PM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
woah....thats the ECE kit in the intended location? I guess I'll have to get some of those offset plates then. I'm running e-fans, but wanted the motor farther back for performance reasons. 2" from the looks of that pic...though I do want to leave enough room to hide the coil packs on the back of the motor so it'll have to be far enough out for that.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-03-2010, 11:16 PM   #7
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
It looks like the fan might go on, but be real close to the rad. very efficient cooling.
Old 08-04-2010, 12:47 AM   #8
Jim_PA
Yep, that's it --
What's the offset plate? You making them yourself?
Every time I look at it, I think about how much I'd like it back about 3-4"
Old 08-04-2010, 12:58 AM   #9
68GMCCustom
I would if I had the stuff to fab them up with. I've seen others that looked similar. I even seem to remember Moroso making some? Here's a pic and link:
adj. mounting plates
Kurt -
Old 08-04-2010, 01:02 AM   #10
68GMCCustom
and some similar plates
Adjustable-Gen-III/IV-LS-info.html
Kurt -
Old 08-04-2010, 01:09 AM   #11
Jim_PA
If I would have been thinking about it from the start, I would have welded 3" of steel to the back of the upper mounting plate, drilled 2 more holes in it, and used them that way.
Not impossible for me to do at this point, but I'm not sure I have the urge to jack everything up and un-do it.
I think they'd be about perfect if you used the back holes in the front of the block, and had that extra 3" or whatever in the back.
Old 08-04-2010, 09:41 AM   #12
glock35ipsc
The position of the middle plate is where mine is.
Bob
Old 08-08-2010, 01:35 AM   #13
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I got it in and here is what it looks like, about 1 1/8". Thinking I might have to cut the bottom out of the shroud and slide it over the top. I will try to figure it out tomorrow.
