Old 08-12-2010, 11:26 AM   #1
djw32
DIY fuse panel/relay for LS motor
Guys,
If I plan on running the factory 5.3 motor in my truck, is there any reason to get a stand alone fuse/relay panel to control my fuel pump?
Has anyone used the factory junction box in their project?
David
________
djw32 is offline   Reply With Quote
Old 08-12-2010, 06:18 PM   #2
djw32
Re: DIY fuse panel/relay for LS motor
Second thought,
Nevermind.
Old 08-12-2010, 07:16 PM   #3
HarrolLS1
HarrolLS1's Avatar
Not sure if this is what you are asking but I hope it helps. It is located in the
"Ls engine swap info" stickyThread ... the link inside that thread says "LT1swap" Lots of wiring info.
http://lt1swap.com/underhoodfuseblock.htm
Harrol
1968 SWB
1968 SWB 4x4
1969 Suburban
1970 LWB
1970 Blazer
2002 Tahoe
Inside every older person is a younger person wondering what happened
HarrolLS1 is offline   Reply With Quote
Old 08-13-2010, 01:32 AM   #4
djw32
Harrol,
Good call on that link.
I forgot to grab the junction block when I picked up the motor...I wasn't thinking.
Old 08-13-2010, 05:54 PM   #5
Ackattack
Ackattack's Avatar
I posted this in my build thread that you asked about, but here it is again...first item on this page is what I used:
http://www.currentperformance.com/Ac...iring_acc.html
Also, I have a factory fuse block that I didn't use.
Ackattack is offline   Reply With Quote
Old 08-13-2010, 10:10 PM   #6
djw32
You used this with the factory ecu, right?
