Help with tire sizes
I am in need of new tires. New engine. go figure. LOL. Anyway currently I am running 15x8 wheels with 255/60 out back and 235/60 up front. I would like to with a wider rear. Any suggestions? No, I'm not buying new wheels, right now.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
BeWarE tHe eViL CrAnkTOe!
I like my 275's but if I was rich like 82BlackBeast I would be running 315's
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods ![]() www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
You can safely fit up to a 295 on an 8" wide wheel (maybe even wider).
Some do not recommend it, but I run them on the front and back with no problems (My front 15x8, my back 15x10). So anything between your current and 295's should not be a problem. Example: 295/50/R15 295 Represents Tire Width 50 Represents the Tire Aspect Ration (Side Wall) The tire aspect ratio changes with tire width. So a 255/50/R15 and a 295/50/R15 will not have the same side wall height! R15 Represents wheel diameter in inches. Here is a web site that should be helpful in determining the tire size you want: http://www.miata.net/garage/tirecalc.html
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
BAD BOW-Silverado XST
i just got my rims and tires mounted
last year i had 15x8s with 235/60 and it was perfectly fine never rubbed up front, i have 245/60s now and the are rubbing on sharp turning ... as for out back i had 275/60s on 15x10s and they rubbed the sidewall when i took a big bump as for now i have 15x8s with 295s and they are perfectly clear of the wheel wells,. that was with my 5/6 drop aswell if i was going to buy new tires (just picked up mine used 10% wear on them) id go with 235/60 and 295/50s
DIGGER 1984 GMC Sierra 1500 LQ4 T56 12B Chopped 2 1/4, Dropped 6/7, Shaved, Yenko Stripes 2004.5 CCSB GMC 2500HD DMAX LLY, 6" Liftmaster, 6 Fox Resi 2.0 325/50/22" Kumho A/T on KMW's LBZ MP, 5"Ex, Bullydog GT 1996 ECSB GMC Sierra 1500 350/4L60E, FL Headers, 2450 Stall, 6" Pro Comp,3" BL, Shock Hoops, , TrXus STS 38's |
Garage Queen Material
i am in need of new tires also.
i'm thinking either 255/60/15's all around or 245/60/15's in front and 295/50/15's in the back |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
