Old 09-13-2010, 12:48 AM   #1
montefreak
montefreak's Avatar
dropping my 67
I have a friend who lowered his 72 with 2 1/2" springs all around..and without changing shocks....is this ok to do???? i am wanting to lower my 67 with little cost involved but i refuse to cut or alter my springs.....please let me know what you think....also...can i just change my springs in the front and use lowering blocks in the back????thank you all..
montefreak is offline   Reply With Quote
Old 09-13-2010, 10:38 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: dropping my 67
You are contradicting yourself here. You say you want to do it cheap, but don't want to cut your front springs. If it were me, I would cut the front coils and use that money saved for new shocks. You might get by with out them, but I would change the shocks anyway.
The best method is new springs and new shocks. If you can't afford that, there is no reason why you can't cut the front coil until you can afoord to do it right. Cut is fine, heating is bad.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-13-2010, 11:52 AM   #3
SCOTI
SCOTI's Avatar
Re: dropping my 67
^^ Cutting in moderation is fine. One coil yeilds 2-3" of drop; don't go beyond that amount.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-13-2010, 08:15 PM   #4
brans72
Re: dropping my 67
What about a 67 using Jeep spring in the back with new shocks is that possible on a tight budget?
brans72 is offline   Reply With Quote
Old 09-14-2010, 12:09 AM   #5
SCOTI
SCOTI's Avatar
Re: dropping my 67
Define tight budget? Depending on how the drop is done, OE replacement shocks are more than acceptable & should fit within a 'tight' budget.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-14-2010, 07:03 AM   #6
brans72
Re: dropping my 67
I wanna cut front spring and put TJ Jeep springs in rear with KYB springs possible without new panhard bar in rear and safe to drive?
Old 09-14-2010, 10:15 AM   #7
SCOTI
SCOTI's Avatar
Re: dropping my 67
1-coil off the front, Jeep springs in the back & KYB GR-2's would be a decent combo.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-14-2010, 07:11 PM   #8
brans72
Re: dropping my 67
ok sounds very do able! What about the bar in the rear can I do without till I can get a nice kit from ECE or can get the correct adjustable bar? Thanks for info Scoti
Old 09-14-2010, 11:32 PM   #9
SCOTI
SCOTI's Avatar
Re: dropping my 67
I've seen them heated & then 'bent' to re-center the rear. On my 67 (back in the day), we cut one end of the Panhard bar & shortened it to the required length. I've learned alot since then & wouldn't shorten one regardless of budget. I would just do a budget long Panhard bar & make my own mounts & such.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-15-2010, 09:19 AM   #10
brans72
Re: dropping my 67
I would just do a budget long Panhard bar & make my own mounts & such. Can you give some more details here please?
Old 09-15-2010, 11:02 AM   #11
SCOTI
SCOTI's Avatar
Re: dropping my 67
Make your own mount that attaches to the pass side truck arm & stretch the OE bar to length. Make your own long/super track bar by taking two short/OE bars & making one long bar. Cut off one end of each OE bar & then thread the ends of the bar the same size as a tie-rod sleeve. Thread the ends into a tie-rod sleeve & it can be adjusted just like a tie-rod is adjusted.
You can also just stretch the OE bar but you need to make sure the length is right before welding it up.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
