Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 10-13-2010, 12:46 PM   #1
djw32
Rebuilt GM 350
Fresh rebuilt 350
2 bolt main
Quadrajet Carb ( the carb shop)
HEI Dizzy
New GM starter
I have two different flywheels for this 350-1 for a turbo 350 and 1 for a 700R4.
I bought this motor from GM. I may have put ONLY 400-500 miles on this motor. Also, I took this motor out for a LS 5.3.
This motor is a ready to run (turn key) motor.
$2,400
Video of the motor running before it was pulled out.
Specs on the motor:
Block: Cast iron, 2-bolt main, 1-piece rear main seal
Connecting Rods: Powdered Metal Connecting Rods
Pistons: Dished Hypereutectic
Compression Ratio: 9.4:1
Oil Pump: High-Volume Oil Pump
Timing Chain: Morse link-type
Camshaft: Flat Tappet Hydraulic (Lift .382" Int/.402" Exh; Duration @ .050" 165.9° Int/174.8° Exh; Lobe Separation Angle 111.9°)
Cylinder Heads: 65.3cc chambers, 1.94"/1.50" valves, swirl port intake design (heads are not performance-oriented; intended for good bottom end torque and fuel economy; intake runner is restrictive because it has a ramp cast into the bottom of the bowl to promote high swirl)
djw32 is offline   Reply With Quote
Old 10-23-2010, 12:32 PM   #2
djw32
Re: Rebuilt GM 350
bump
Old 10-23-2010, 02:08 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Rebuilt GM 350
from the sellers Code of Conduct 67-72chevytrucks.com
VI.If you do not like the price of an item, look further. Comments on value, condition etc will not be tolerated.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 10-24-2010, 08:29 PM   #4
djw32
Re: Rebuilt GM 350
I hear ya, but...This is a brand new motor with 400ish( mi truly believe that this motor has less than 400 miles on it) miles on it. There is no way you could find a complete, brand new Chevy 350 for this price. Just so you know, I'm taking a steep hit in the wallet by selling it for $2400. Hell, the long block cost about $2300 ish, than I am throwing in the factory accessories( with A/C pump & power steering), HEI distributor, rebuild Q-Jet from the carb shop, and this motor still may have the factory warranty from GM... I think it is a pretty good deal.
Old 10-25-2010, 01:41 PM   #5
STOCKISH
STOCKISH's Avatar
Re: Rebuilt GM 350
Trust me, I know. I do this for a living and have bought and installed more GM engines in peoples trucks than I can remember. I was not saying your price was out of line of that your engine was not worth it either. I was only saying if you were in a hurry to unload it to recoup cash for your LS swap that you MAY have to come off a little. I'm sure if you hold out for a while, someone will gladly pay what you want just because of how complete it is and how easy it will make someones project. Hope you didnt take what I was saying the wrong way. Good luck on your sale.
--Josh
Old 11-10-2010, 02:32 AM   #6
djw32
Re: Rebuilt GM 350
bump
Old 12-08-2010, 01:33 PM   #7
djw32
Re: Rebuilt GM 350
ttt
