Old 11-02-2010, 02:59 PM   #101
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
I've actually thought about doing a steel inner if I did this project. I wonder if you could take another roof skin from another burb, or the left over from the rear of the cut off area that is not used at all, trim it down and use it? Maybe put some bows in there first, tack them to the outer skin and the inner top of the burb roof to cab framing. Then place the trimmed burb roof skin in and pre drill some holes to be able to spot weld to the bows. This would be real easy to do if you have a way to stand the cab up on its back or flip it on its side I think. IDK, just some ideas I have been tossing around.
Ryan
1969 Chevy milk truck
Old 11-02-2010, 03:07 PM   #102
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Just a thought ..... How about the inner skin out of a newer crew cab ???
ksbrktracer is offline   Reply With Quote
Old 11-02-2010, 03:07 PM   #103
68 TT
Still plays with trucks
68 TT's Avatar
It will be a ton of work either way to get a smooth headliner.
A traditional vinyl one with bows like a 60's car used would be easiest. Just bend up some 1/4" rod to the contour you want and mount them with clips in the center and receiver pockets on the edges to hold them in place. Hand it off to an upholstery shop and let them have at it. The edge trim may take a little work but nowhere near what the smooth headliners would take. The upholstery shop could probably take care of the edge trim too.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 11-02-2010, 03:14 PM   #104
68 TT
68 TT's Avatar
Cut that out. It would be too easy. Maybe.
I think the newer cab is a bit wider at the top but it would be a good place to start. A little sectioning and welding and it could work out pretty well with a whole lot less work than fabricating one from scratch.
Old 11-02-2010, 03:15 PM   #105
Dieselwrencher
Personally, I'd either want a steel inner of go the fiberglass route. My friend had a 48 Chevy the size of a crew cab but only a 2 door. He had an old style cloth and bow headliner in it once. It just looked out of place so he built a fiberglass one. That was the ticket! 5 years later he built another one and this time he did steel. That was even better IMO.
Ryan
Old 11-02-2010, 03:18 PM   #106
67cheby
67cheby
67cheby's Avatar
why not just weld a couple of reg cab inner roof panels together and make it look like it was made that way ??
67cheby is offline   Reply With Quote
Old 11-02-2010, 03:25 PM   #107
ksbrktracer
TNT-MOTORSPORTS
That was my first thought , probably need 3-4 of them to get enough metal I'm guessing
Old 11-02-2010, 03:29 PM   #108
Dieselwrencher
That is a good idea too. It would be a lot of cutting and welding, but I guess that is the whole project.
Ryan
Old 11-02-2010, 03:31 PM   #109
67cheby
67cheby
67cheby's Avatar
i think it would be a lot more "impressive" and look like it is done right !! i saw an extended cab 68 done like this prob 15 years ago , and i still remember that trucks headliner today !!
Old 11-02-2010, 03:34 PM   #110
68 TT
68 TT's Avatar
It would be a whole lot easier to find a few regular cab roof sections than it would to snag one crew cab roof too.
Old 11-02-2010, 03:37 PM   #111
scooterskoolkustoms
scooterskoolkustoms's Avatar
WOW you have some balls,the truck was nice to start with and you are doing a great job.not just anybody can cut up a truck,keep up the good,no I mean great job.
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
Old 11-03-2010, 09:32 PM   #112
JRBECK64
I am completely blown out of my socks by this build. My hats off to you and I dont take my hat off for anyone. Its refreshing to see new ideas coming to fruition. GREAT JOB.
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 11-03-2010, 11:51 PM   #113
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
JRBECK64
Thanks so much for the props!
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 11-04-2010, 07:46 AM   #114
Strut
Strut's Avatar
What do you think about getting a Headliner out of a new model Tahoe or Suburban? I dont know what the size of your roof is, but if the headliner was to big it would be easy to cut and glue back together.... Then you have a foundation for you fiberglass work.... Should be able to soak the headliner with resin and harden it. You might still want to use some fiberglass mat to reinforce it some.
Just an idea...
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 11-05-2010, 10:50 PM   #115
drewskiren
drewskiren's Avatar
Just an idea...
Just the kind of idea I am looking for!!! Might work.
Drew
Old 11-06-2010, 07:01 AM   #116
jbclassix
Junk Yartist
jbclassix's Avatar
my suggestion is a 1992-2000 chevy crew cab headliner if you are going to put in a headliner. it has a low roofline and simple curves. otherwise, what about using several inner roof pieces from a truck and then covering them with material? It wouldnt be removeable though.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 11-06-2010, 08:53 AM   #117
Hart_Rod
Hart_Rod's Avatar
That's how mine was done. here's a couple of pictures:
Hart_Rod is offline   Reply With Quote
Old 11-06-2010, 10:48 AM   #118
ksbrktracer
TNT-MOTORSPORTS
We have a winner ... That's the way I would do mine. Then maybe add a super headliner ....!!
Old 11-06-2010, 10:53 AM   #119
67cheby
67cheby
67cheby's Avatar
That looks killer, imho that is the only thing that looks right !! Nice job by the way
Old 11-06-2010, 11:35 AM   #120
Hart_Rod
Hart_Rod's Avatar
Thanks. Drew, have you started on your chassis yet? If you have questions, give me a call.
R/
Old 11-06-2010, 01:10 PM   #121
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I like the steel headliner idea looks factory..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-06-2010, 01:47 PM   #122
drewskiren
drewskiren's Avatar
My reinforcing rib hangs down in the way. Can't do it that way/ worried if I take out the rib it is too flexy. I really want a cloth headliner on a cardboard/fiberglass insert. Now I am thinking about how to make that and finish the edges.
Drew
Old 11-06-2010, 02:23 PM   #123
67cheby
67cheby
67cheby's Avatar
the headliner would be the support you need that would take the place of the bow your talking about
Old 11-06-2010, 05:16 PM   #124
Beautiful work so far. I am really enjoying your build.
Old 11-07-2010, 07:36 PM   #125
drewskiren
drewskiren's Avatar
Remember the 100 dollar cabs I got? Well they came with doors too which I need to steal something off of. Measured 3 or 4 times on the drivers side only to cut it an eighth inch too short. DOH!!! Some surgeon I am. Passenger side I drilled out the spot welds and removed a good bit into the door. I'll just plug weld the holes at the bottom and butt weld at the top frame.
Drew
