#1526 |
Too Dumb To Know Better
Re: PO has me PO'd
Grew up in Idaho. Had alot of California hunters come up and shoot cows. (moo). We started calling them slow elk.
#1527 |
Re: PO has me PO'd
Thanks again! More great pictures, good river fishing too! course i'm more of a drift fisherman than a fly fisherman..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#1528 |
GEARHEAD
Re: PO has me PO'd
My wifes is from Idaho Falls. We usually go through the park or take the routes south on the west side and through West Yellowstone when we go to visit. Her mom lives in St Anthony where they have the sand dunes. Very fun place to play with a truck. Another good source for solid sheetmetal also.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#1529 | |||
Re: PO has me PO'd
swamprat, drift fishing in a drift boat, or a method of fishing? hgs_notes, I envy all you people that had the chance to grow and live in the great open spaces of our country, I on the other hand only had 1 week to enjoy it, but it will be memories that I keep a lifetime From Bozeman south for 1 hour I must have seen 30 trucks of our vintage!! One more day and I will post up more pics of the Lokar install...
#1530 |
Re: PO has me PO'd
Bank fishing using corkies and yarn, sand shrimp salmon row, allowing the weight to just lightly tap across the bottom on occasion, also spinners and spoons. Where i live now were talking about salmon and steelhead. I don't have a drift boat but its pretty much the same concept, i have been in drift boats and river sleads tho, its a kick in the pants! However i grew up in eastern washington fishing for trout, in rivers and streams i used a lot of wedding rings tipped with a worm or night crawler, sometimes just a worm with some split shot.
#1531 | |
Re: PO has me PO'd
![]() We usually start fishing Salmon in Sept., and then switch over to Steelhead in Nov., Dec. We use drift boats after Dec. as it gets toooo cold to stand in the water for 8-10 hours (15 degrees last Feb)
#1532 |
Re: PO has me PO'd
![]() had to reverse the mounting plates, since they would interfere with the shift arm, also radiused the plate about 3/32". Then it was just drilling 2 5/16" holes and cutting 2 parallel lines with my Dremel cutoff wheel ![]() bending the ring to match the hump is the next challenge ![]() ![]() next step is to work on the actual linkage...problems! Seems the billet aluminum arm on the trans. is better suited for 5/16" then the 1/4" rod and ends that come with the kit. Sooo, calling McMaster-Carr, they had the rod ends and rod instock (5/16"), ship today, have tomorrow. Gotta luv a welled stocked hardware store online
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-16-2010 at 03:09 PM. |
#1533 |
Re: PO has me PO'd
![]() went a little beefier then the stock screws, it's a truck ,right? still have to trim the boot more rod ends w/studs to replace the original parts, 5/16" instead of 1/4" ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-18-2010 at 12:01 AM. |
#1534 |
Re: PO has me PO'd
![]() the advantage of using a stud on the rod end is that the billet arm has a recess machined in the backside, and this is just the right size to hold the hex head of the stud ![]() don't forget to use anti-sieze on any stainless hardware, or it will gall and snap the bolt...still need to change out to a stud, probably change to LH thread to make it easier the adjust
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-22-2010 at 10:03 PM. |
#1535 |
Back in the sticks
Re: PO has me PO'd
That is nice! I thought you were building a Jimmy tho, not the space shuttle!!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#1536 |
Re: PO has me PO'd
![]() this angle fits your statement better ![]() ![]() new set back... PO felt the need to resize the pivot bolt hole for the transfer case shifter, no provision for the bushing, just drilled and tapped bigger. Out comes the T/C, again! All I wanted to do was mount the ring and boot, but that ain't happenin' till I fix the pivot bolt, and while I'm in there, I might as well put new seals and bearings in the coupler
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-23-2010 at 02:06 PM. |
#1537 | |
Back in the sticks
Re: PO has me PO'd
Houston, we have a problem! J/K, sorry to hear you have to take it out again, I know re-engineering crap sucks. Luckily, I only had to pull the T/C twice when I put the throwout bearing in backwards.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty Last edited by red71cheyenne; 11-23-2010 at 11:21 PM. Reason: info |
#1538 | |
Its lookin' like a Blazer!
Re: PO has me PO'd
#1539 | |
Re: PO has me PO'd
![]() COMING SOON!!! at a forum near you...TWIN STICKING the new process NP205 and K case TH 350 might as well right? T/C is already out, and I want to be able to run it in 2WD on the front axle only, thus avoiding the ass end from coming around in the snow!!! couple coats of rustoleum oil based flat white ![]() ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-29-2010 at 03:40 PM. |
#1540 |
Re: PO has me PO'd
That sounds like my house!!! :p
#1541 |
Re: PO has me PO'd
Ok, seeing your pic's brought back some memorys i'd just assume forget, all i had was a small 1 ton floor jack and it was not tall enough to lift my T case or my tranny high enough to do the install, so i ended up pushing them off to the side a little and positioned myself under the center of my truck, then i pulled the tranny onto my chest and used my arms and my knee to heft it up into place, then i had to do the same with the T case.. that was a beotch!
#1542 |
Re: PO has me PO'd
OK, ordered up the Twin Stick and long shift rails from ORD, should be here in a couple days! Since the mount for the shifter doesn't use the factory hole, I can use the defective coupler that is in the truck with new seals from 4X Heaven outta NY
The boot may cause a problem, but what else is new? Right!
#1543 | |
Re: PO has me PO'd
![]() ![]() plus. plus it was only 100 bucks at Harbour Freight
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-01-2010 at 12:46 AM. |
#1544 | |
Re: PO has me PO'd
Yep been there, own that T-shirt too. |
#1545 | |
Re: PO has me PO'd
#1546 |
Re: PO has me PO'd
sorry, just playin with the photobucket, problems downloadin
![]() ![]() tool I used to get the second roll pin started ![]() front wheel drive only ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-08-2010 at 02:32 AM. |
#1547 |
Re: PO has me PO'd
Your going to love the twin stick, comes in handy...a lot!
#1548 |
Re: PO has me PO'd
thanks Kurt, saw you use it alot, and had to have one
![]() used some exhaust manifold studs to help get things aligned, don't forget to put it in gear and rotate the tailshaft, don't ask how I know... ![]() ![]() problem with the passenger side diagonal brace on the crossmember, need to cut a 1 1/2" square to clear the pivot bolt
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-08-2010 at 04:54 PM. |
#1549 |
Re: PO has me PO'd
Just make sure the rear of the 205 is mounted correctly, ask me how I know.
#1550 | |
Re: PO has me PO'd
![]() are you referring to the side mount, when you state that it needs to be properly mounted???
