11-25-2010, 01:25 AM | #1 |
big block picture
Ok Guy,
Lets see some pictures of your big blocks in your trucks I need some Ideas for my conversion.
John Bernard Books (The Shootist): "I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I expect the same from them." |
11-25-2010, 01:34 AM | #2 |
Re: big block picture
Here is my recent 454 swap, still isnt done, I need to sort a different air cleaner base to use a stock tall small block air cleaner, and likely swap out that vacuum secondary, for a double pumper.
Might try to start on a stroker 496 to swap in also, this is a new motor, but who doesn't like more power. |
11-25-2010, 08:15 AM | #3 |
Is this just a preference? I bought a vac secondary 750 cfm Holley based on a few recommendations from people. I am building a 468 for my truck. I am not questioning your decision just curious since you have experience with it.
11-25-2010, 05:57 PM | #4 |
baclay9, the one in the pic is a 750 also. I guess in some ways its more of a preference, the vacuum secondary can be tuned to run good, and will probably get better gas mileage if you're in the back two barrels a lot, but if you're running a big block in a daily driver, usually gas mileage isn't a main concern, and unless you're really getting in it, the back barrels don't come into play that often. Or atleast that's how I drive/see it.
The vacuum secondary model is good, but it lacks a metering plate for the back barrels, and relies on different weight springs for tuning them also. It also lacks the second accelerator pump. With the vaccum, it will only open as far as the engine needs, not giving it excess air or fuel, or atleast in a perfectly set up condition, that would be its only benefit. Myself, I like a direct mechanical linkage to the back barrels, the ability to jet and adjust the back, also the improved idling circuit, plus the second accelerator pump gives it a bit more kick. Granted tuning a double pumper can be a pain at times also. I'm pushing the edge of lean on my motor now, right around 460ci at .030 over, and has a mild cam, I haven't cared to pull a bowl and check the jets, as the carb just came with the rebuilder. Its probably getting ditched as soon as I feel like cleaning up a 850 double pumper. |
11-25-2010, 06:02 PM | #5 |
Thanks man, I have a couple more questions for you but I think I will PM you. I don't want to derail the OP...
11-28-2010, 12:28 PM | #6 |
Really guys!
200 views and only 4 posts, more people have got to have pictures of big blocks in square trucks. I'm stuck in Afganistan someone please give me some motivation.
11-28-2010, 04:51 PM | #7 |
Old Heap Driver
Here ya go................
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
11-28-2010, 04:52 PM | #8 |
Old Heap Driver
The fan shroud sticker............Folks kept asking me if the motor is a 572, no, it's a 454. So, I had a sticker made that says, "572 CLONE", gets a lot of laughs.
11-28-2010, 09:20 PM | #9 |
S10Fan, nice looking engine bay. Are you running a brake booster?
Snagged a hydroboost unit for my truck tonight, figure it will give me more clearance, plus they just look sexier than vacuum boosters. |
11-28-2010, 09:24 PM | #10 |
11-28-2010, 09:27 PM | #11 |
Old Heap Driver
Thanks!
Manual brakes, stops on a dime. I'm going to convert my S-10 to manual brakes as well.
11-28-2010, 09:32 PM | #12 |
Old Heap Driver
Thanks!
Wanted something different so stainless tubing was called to duty. I used TIG rod to make a pattern then had them bent at a local industrial supply shop. Ran me right at $40.00 for both sections including the bend labor.
11-28-2010, 09:52 PM | #13 |
GM's 4 Life
Heres mine and really need to pull it out because sadly the tuck is a rust bucket.
[ O yeah it's a 468
Jack '54 Chevy 3100 "Just a Mess" '74 Chevy Super 10 468BB "One Fast Rust Bucket" '86 Pontiac Fiero GT '88 Chevy burb "Tha Big Turd" '93 GMC Safari "Bone Crusher" .................____________ .............../______l___|___\____ ;,;,;,;,;,;,;|__(O)_| __l___l__(O) | Last edited by Da88burban; 11-28-2010 at 10:05 PM. |
11-28-2010, 10:03 PM | #14 |
GM's 4 Life
But it was a 454
11-28-2010, 10:43 PM | #15 |
here's out
and here's in
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
11-28-2010, 10:57 PM | #16 |
There has to be more Big Blocks in squares on here. I have my eye on a 454 that is in my jobs shop truck. It's an 89 3/4 ton and we use it to pull diesel school buses around the yard. That truck will not quit. I need to get a pic of it.
America is all about speed, hot nasty bad ass speed |
11-28-2010, 10:58 PM | #17 |
What size is the tubing man. That looks really clean!!! Where did you get the little clamps that are holding the pipes together? Also, did you have the ends flared at all?
11-28-2010, 11:28 PM | #18 |
GoatLube Experss
this is all I have with me , I'll have to get my girlfriend to send me some current picture's with it all put back together !
S10Fan yours really look's good.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
11-29-2010, 01:42 AM | #19 |
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
11-29-2010, 01:50 AM | #20 |
Da88burban, I dig your engine.
Really like the vintage valve covers, and the look, there is just something about the dirty old motor that turns me on. |
11-29-2010, 03:31 AM | #21 |
See I knew we had to have some Beef Eatters on here.
Thanks for weighting in guys.
11-29-2010, 04:01 AM | #22 |
My dads freshly installed 468
Flowershop Hip Hop & Street Rods Dropmember 83 Custom Deluxe Almond on Almond 85 Silverado White on Red/Now Chevy LeMans Blue Rendering in Truckin magazine vol 36 no. 11,2010 |
