Old 11-25-2010, 01:25 AM   #1
J/D/S
big block picture
Ok Guy,
Lets see some pictures of your big blocks in your trucks I need some Ideas for my conversion.
John Bernard Books (The Shootist):
"I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I expect the same from them."
J/D/S is offline   Reply With Quote
Old 11-25-2010, 01:34 AM   #2
Dru
Re: big block picture
Here is my recent 454 swap, still isnt done, I need to sort a different air cleaner base to use a stock tall small block air cleaner, and likely swap out that vacuum secondary, for a double pumper.
Might try to start on a stroker 496 to swap in also, this is a new motor, but who doesn't like more power.
Dru is offline   Reply With Quote
Old 11-25-2010, 08:15 AM   #3
baclay9
Is this just a preference? I bought a vac secondary 750 cfm Holley based on a few recommendations from people. I am building a 468 for my truck. I am not questioning your decision just curious since you have experience with it.
baclay9 is offline   Reply With Quote
Old 11-25-2010, 05:57 PM   #4
Dru
baclay9, the one in the pic is a 750 also. I guess in some ways its more of a preference, the vacuum secondary can be tuned to run good, and will probably get better gas mileage if you're in the back two barrels a lot, but if you're running a big block in a daily driver, usually gas mileage isn't a main concern, and unless you're really getting in it, the back barrels don't come into play that often. Or atleast that's how I drive/see it.
The vacuum secondary model is good, but it lacks a metering plate for the back barrels, and relies on different weight springs for tuning them also. It also lacks the second accelerator pump. With the vaccum, it will only open as far as the engine needs, not giving it excess air or fuel, or atleast in a perfectly set up condition, that would be its only benefit.
Myself, I like a direct mechanical linkage to the back barrels, the ability to jet and adjust the back, also the improved idling circuit, plus the second accelerator pump gives it a bit more kick. Granted tuning a double pumper can be a pain at times also.
I'm pushing the edge of lean on my motor now, right around 460ci at .030 over, and has a mild cam, I haven't cared to pull a bowl and check the jets, as the carb just came with the rebuilder. Its probably getting ditched as soon as I feel like cleaning up a 850 double pumper.
Old 11-25-2010, 06:02 PM   #5
baclay9
Thanks man, I have a couple more questions for you but I think I will PM you. I don't want to derail the OP...
Old 11-28-2010, 12:28 PM   #6
J/D/S
Really guys!
200 views and only 4 posts, more people have got to have pictures of big blocks in square trucks. I'm stuck in Afganistan someone please give me some motivation.
Old 11-28-2010, 04:51 PM   #7
S10Fan
Old Heap Driver
Here ya go................
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 11-28-2010, 04:52 PM   #8
S10Fan
Old Heap Driver
The fan shroud sticker............Folks kept asking me if the motor is a 572, no, it's a 454. So, I had a sticker made that says, "572 CLONE", gets a lot of laughs.
Bryan
Old 11-28-2010, 09:20 PM   #9
Dru
S10Fan, nice looking engine bay. Are you running a brake booster?
Snagged a hydroboost unit for my truck tonight, figure it will give me more clearance, plus they just look sexier than vacuum boosters.
Old 11-28-2010, 09:24 PM   #10
thepenguin99
VERY NICE, I love the heater hose routing.
thepenguin99 is offline   Reply With Quote
Old 11-28-2010, 09:27 PM   #11
S10Fan
Old Heap Driver
Thanks!
Manual brakes, stops on a dime. I'm going to convert my S-10 to manual brakes as well.
Bryan
Old 11-28-2010, 09:32 PM   #12
S10Fan
Old Heap Driver
Thanks!
Wanted something different so stainless tubing was called to duty. I used TIG rod to make a pattern then had them bent at a local industrial supply shop. Ran me right at $40.00 for both sections including the bend labor.
Bryan
Old 11-28-2010, 09:52 PM   #13
Da88burban
GM's 4 Life
Da88burban's Avatar
Heres mine and really need to pull it out because sadly the tuck is a rust bucket.
O yeah it's a 468
Jack
'54 Chevy 3100 "Just a Mess"
'74 Chevy Super 10 468BB "One Fast Rust Bucket"
'86 Pontiac Fiero GT
'88 Chevy burb "Tha Big Turd"
'93 GMC Safari "Bone Crusher"
.................____________
.............../______l___|___\____
;,;,;,;,;,;,;|__(O)_| __l___l__(O) |
Da88burban is offline   Reply With Quote
Old 11-28-2010, 10:03 PM   #14
Da88burban
GM's 4 Life
Da88burban's Avatar
But it was a 454
Jack
Old 11-28-2010, 10:43 PM   #15
pig rig
pig rig's Avatar
here's out
and here's in
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 11-28-2010, 10:57 PM   #16
JuicyJ
JuicyJ's Avatar
There has to be more Big Blocks in squares on here. I have my eye on a 454 that is in my jobs shop truck. It's an 89 3/4 ton and we use it to pull diesel school buses around the yard. That truck will not quit. I need to get a pic of it.
America is all about speed, hot nasty bad ass speed
JuicyJ is offline   Reply With Quote
Old 11-28-2010, 10:58 PM   #17
baclay9
Thanks!
What size is the tubing man. That looks really clean!!! Where did you get the little clamps that are holding the pipes together? Also, did you have the ends flared at all?
Old 11-28-2010, 11:28 PM   #18
jitteryguy
GoatLube Experss
jitteryguy's Avatar
this is all I have with me , I'll have to get my girlfriend to send me some current picture's with it all put back together !
S10Fan yours really look's good.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 11-29-2010, 01:42 AM   #19
LiveAnimals
LiveAnimals's Avatar
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 11-29-2010, 01:50 AM   #20
Dru
Da88burban, I dig your engine.
Really like the vintage valve covers, and the look, there is just something about the dirty old motor that turns me on.
Old 11-29-2010, 03:31 AM   #21
J/D/S
See I knew we had to have some Beef Eatters on here.
Thanks for weighting in guys.
Old 11-29-2010, 04:01 AM   #22
BIG KRIS
BIG KRIS's Avatar
My dads freshly installed 468
Flowershop Hip Hop & Street Rods
Dropmember
83 Custom Deluxe Almond on Almond
85 Silverado White on Red/Now Chevy LeMans Blue
Rendering in Truckin magazine vol 36 no. 11,2010
BIG KRIS is offline   Reply With Quote
