Old 12-05-2010, 11:34 PM   #1
samstheman
Grandpas 1977 Stepside
New here Hi all. I just inhereted my grandpas 1977 stepside. I plan on going threw most of it. I didn't get a pic when I got it but had a campershell which I removed. The tires are 31" on 15'' rims. I want to put 18 or 20s on it. I lowered it 5" in front 3'' spindle and 2'' spring. I also powder coated upper and lower control arms and cleaned all rust of frame and other parts and painted with por15.I am going to lower back next any advice on how much would be appreciated. I would like it to have a little rake.
samstheman is offline   Reply With Quote
Old 12-05-2010, 11:40 PM   #2
spudz
spudz's Avatar
Re: Grandpas 1977 Stepside
looks nice!
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 12-05-2010, 11:57 PM   #3
samstheman
Old 12-06-2010, 12:42 AM   #4
cable666guy
cable666guy's Avatar
Good looking truck! Looks like a clean one...Keep checking other guys builds, there are tons of lowered trucks here... I think you may be in axle flip territory even with a moderate rake...the guys on this board will steer you in the right direction!!
cable666guy is offline   Reply With Quote
Old 12-06-2010, 12:45 AM   #5
benoit454
Chris
benoit454's Avatar
looks good I'd love to have it. Or I should say one like it.
Dids that ratchet strap really work? I was too scared to try one, I left my jack under there when we did a new upper control arm andnew lower ball joint on my old man's 84.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 12-06-2010, 12:46 AM   #6
samstheman
Cool I could use some input on wheels and tire and offsets
Old 12-06-2010, 12:49 AM   #7
samstheman
I used the strap just to get to nuts the bushings were so worn it wouldn't stay out of the way.
Old 12-06-2010, 02:10 AM   #8
Devillusion
Devillusion's Avatar
nice work....
Devillusion is offline   Reply With Quote
Old 12-06-2010, 01:54 PM   #9
benoit454
Chris
benoit454's Avatar
ohhh Ok I did the same thing just had my old man behind me using a crow bar lol.
Chris
GIT R DONE!!!!!!
Old 12-06-2010, 03:07 PM   #10
79beater
79beater's Avatar
Good start!
79beater is offline   Reply With Quote
Old 12-06-2010, 03:35 PM   #11
nbpro
clean truck nice work
nbpro is offline   Reply With Quote
Old 12-06-2010, 10:31 PM   #12
87 chevy silverado
looking nice
87 chevy silverado is offline   Reply With Quote
Old 12-10-2010, 12:59 AM   #13
samstheman
Thanks for all the comments I should be trying to put rear flip kit in soon. Then to the wheel sizes back space and a whole other bag of worms Im not sure of. I would like to put 20s but I want a little more side wall than a rubberband. So I may go 18s and more side wall not sure though. I saw some good looking trucks on here with 20s. Sizes with back space options would be good if anyone has them and any mods I might encounter.
Old 12-30-2010, 01:19 AM   #14
samstheman
Well had 2 weeks off work. It rained most of the time. I finished up front suspension and moved on to the rear with a good clean up and a por15 paint job on frame and rear end up to the last body mount. I painted the under side in 3 sections I still have the middle to do. I installed DJM 5'' flip kit they have a couple of issues with that kit. The shock bolts on outside need to be moved up about 3/4'' if your using 4 leafs they end up on top of each other the driver side is worse than passenger. Other than that everything went ok. I went with 5/5 I like the rake front wheel 20x8.5 rear wheel 20x10.
Old 12-30-2010, 02:05 AM   #15
sgtvanmp
sgtvanmp's Avatar
Great looking truck. Keep up the work and adding pics.
sgtvanmp is offline   Reply With Quote
Old 12-30-2010, 10:37 AM   #16
russgt
russgt's Avatar
Damn, that turned out very nice
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 12-30-2010, 12:59 PM   #17
dlhughes2005
Great wheel and tire choice! How big of a pain was it painting the frame with the body still on? Suspension came out nice to, love how clean the frontend looks.
85 GMC SWB: Fuel Injected 454, TH400, soon to be laying frame on 22s
96 Trans-Am: Full bolt-ons, Weld Rodlite skinnies and fatties
95 GMC Yukon 4x4: 2door all stock with the exception of glasspacks and duals
dlhughes2005 is offline   Reply With Quote
Old 12-30-2010, 01:27 PM   #18
samstheman
Thanks all, I jacked it up one end at a time as high as my jack stands would go with a second set on also. And put rust remover grinder on a electric drill motor that was messy. When I painted it I used googles and mask cause all the overspray floats around . I will mask the frame and other painted parts and under coat inside panels the same way . I will pull off bed and clean up bottom of bed. I want to keep it drivable and not let the project overwhelm me by having every part taken off. Its not a show truck its just nice to work on it and have some fun with.
Old 03-06-2011, 10:21 PM   #19
samstheman
I finally installed sway bars front and rear handles great but still a little bouncy have to work on that. I took out old orig 3 speed trans and installed 5 speed borg warner T5 from junk yard Makes the truck a lot faster and smoother . Im working on bodywork now hoping to get this thing painted in the next few months. still not sure what to do with my straight 6 I got it running great has slight mis off idle still have to smog this truck
Old 03-07-2011, 02:30 PM   #20
ds350
Truck is looking great! Do you have some more details on the T5 swap?
ds350 is offline   Reply With Quote
Old 03-07-2011, 05:09 PM   #21
samstheman
Thumbs up Re: Grandpas 1977 Stepside
Stock bellhousing, astro van 11'' clutch, stock 3 speed presure plate and flywheel. That was the easy bit then you need to measure all parts on old 3 speed trans from the mounting surface as your baseline and trim down all the parts on t5 to match old 3 speed trans there is lots of resources on net. Which models have what gears and mech or computer speedo. I also made a quick shift conversion also works well with long truck style shifter. Anything specific u wanting to know. And move stock cross member towards back wheel. And shorten drive shaft 3". T5 3'' loner than stock trans It was all worth it drives really good now.
Old 03-07-2011, 06:13 PM   #22
burger
Nice looking truck. What are the tire sizes?
burger is offline   Reply With Quote
Old 03-07-2011, 10:05 PM   #23
slammed427
slammed427's Avatar
I've been trying to find swap info for the square's but not having much luck. Do you have any links handy? I'm trying to figure out how much to take off the input shaft. Any help would be awesome.
slammed427 is offline   Reply With Quote
Old 03-07-2011, 11:48 PM   #24
samstheman
255/45/20on 8.5'' rim
295/45/20on 10'' rim
Old 03-07-2011, 11:53 PM   #25
samstheman
http://www.flatheadv8.org/ernie/ernie-t5.htm
http://www.flatheadv8.org/t5-swap.htm
Your input shaft gets cut down on the very tip about 3/8 of in. THe t5 tip is to long. You can measure your hole to double check with some calipers. Or check and old 3 speed trans for overall length.
