Square making a turn?
Hello , I am looking to improve the handling on my old 86 it’s a swb 2wd no factory sway bar , my first idea is to put all new bushing in the control arms and install a sway bar I’m wondering what brand bar and bushing should I bee looking at the truck is its stock ride height, and (I would like to keep it that way) with 15x10 275,60 tires all the way around , and if a rear sway bar is worth the money, any incite would be greatly appreciated
Re: Square making a turn?
pic of the truck
Get the rear sway bar, thickest you can, and upgrade your front bar to a stock 1 ton unit with poly bushing all around. It'll be a night and day difference.
grab the rear off of a 1 ton camper special also thats about the cheepest way to go
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
If you truck was not equipped with a rear sway bar it's not going to have the bolt holes for it right? or did they just make the holes on all frames and then added the sway bar later? I have a front one but I'm looking to get a rear one
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
thank you , should i try to get the front out of lmc? ill go threw the local junkyards this weekend to see what i can find for the rear but i dont have any luck were should i look to buy them from?
Happy to be here
![]() Join Date: Mar 2000
Most 2wd Burbs came with front sway bars, and you can look at C20's as well. Its easy to find a front bar, the rears are not so common. If your truck did not come with a bar, it probably won't have the mounting stands. These are riveted to the frame so it takes a bit of effort to retrieve them.
Insert Witty Text Here
Adding a front swaybar from the local junkyard (none on the rear) made a huge difference in the handling on my truck. It was probably the most cost effective modification i have made to it in the 10 years i have owned it.
Slonaker |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
