Old 12-26-2010, 05:30 PM   #1
blu-by-u-2
blu-by-u-2's Avatar
Why am I leaking feul?
Hey guys. I put my old holley carb back on this weekend, the edelbrock was second hand and just was not working out. Anyway, when I start it, it runs for about 5-7 seconds then fuel starts coming out of the air horn for about 5-7 seconds then it seems to stop. Then when I shut off the engine Its like smoke or vapors or something coming out of the carb for about 10-15 seconds. Any help would be great! thanks
77 k5 2wd
76 k5 jimmy 4x4
97 c1500 2wd
06 chrysler 300 on 22"s
blu-by-u-2 is offline   Reply With Quote
Old 12-26-2010, 05:41 PM   #2
bowtiecb
bowtiecb's Avatar
Re: Why am I leaking feul?
sound likes its loadn up, try tapn the float bowls or adjusting the floats, might have trash in it
bowtiecb is offline   Reply With Quote
Old 12-26-2010, 06:08 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, your float is stuck open. Either the float is bad or the needle and seat need cleaning or replacing.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-26-2010, 06:21 PM   #4
mooseknuckles
mooseknuckles's Avatar
the float is stuck prob dirt in the needle and seat. you should have a fuel filter where that piece of rubber hose is. lol
mooseknuckles is offline   Reply With Quote
Old 12-26-2010, 06:25 PM   #5
blu-by-u-2
blu-by-u-2's Avatar
oh there is I keep stuffing toilet paper in the rubberhose. lol!
77 k5 2wd
76 k5 jimmy 4x4
97 c1500 2wd
Old 12-26-2010, 06:32 PM   #6
blu-by-u-2
blu-by-u-2's Avatar
Oh yeah, also the two adjusting screws on the sides of the front floatbowl doesn't seem to change idle when adjusting them. Why is that ?
77 k5 2wd
76 k5 jimmy 4x4
97 c1500 2wd
Old 12-26-2010, 06:39 PM   #7
Tx Firefighter
You'll need to square away the flooding issue before you can judge the idle mixture adjustment screws. With excess fuel going down the venturi you're not going to get anything meaningful out of adjustments.
Old 12-26-2010, 07:56 PM   #8
blu-by-u-2
blu-by-u-2's Avatar
Well imagine that! took float bowls off tht floats seemed to look fine.I did bend tab on the front float just a hair for a better shutoff though. Put back together. Started up and............. NO MORE FUEL LEAKING !!! Thanks guys. And when I shut it off no more smoke or fog or whatever that was before.
77 k5 2wd
76 k5 jimmy 4x4
97 c1500 2wd
