Old 12-29-2010, 08:42 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Installing new seat cover...
I've never done it before, and thinking about tackling it... Is it easy? Or are the hog rings as much of a PITA as I've been told by people? Is it worth spending the 50 bucks or whatever to have it professionally done? Thanks!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 12-29-2010, 09:39 PM   #2
merc64
merc64's Avatar
Re: Installing new seat cover...
I just did this on my 79. The hog rings aren't the hard part, it's stretching the new cover to fit properly without tearing a seam. I've replaced seats covers in two different vehicles and if you can get someone to do it for 50 bucks I say go for it.
merc64 is offline   Reply With Quote
Old 12-29-2010, 10:10 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
its pretty easy. i did one on my 85, you have to take the back off the base to get the cover on. but is easy to get it off. i had more trouble taking the old cover off than i did putting the new cover on. just make sure the cover is at room temp before you put it on, especially if its vinyl
95 S_Trucker is offline   Reply With Quote
Old 12-29-2010, 10:38 PM   #4
69GMC910
MOTORHEAD!
69GMC910's Avatar
Okay, cash is a little tight right now, so maybe I will try it myself... Maybe even get the wife involved! Won't she be happy....!!!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 12-30-2010, 04:27 AM   #5
merc64
merc64's Avatar
LOL, my wife helped me and it only took us a few hours with alot of breaks. Also, you can use a hair dryer to heat up the vinyl which makes it easier to stretch.
Old 12-30-2010, 05:04 AM   #6
85silverbeast
85silverbeast's Avatar
If you can have it professionally done for $50.00 go for it to install a cover on a bench here in AZ its about $120.00 from a reputable shop.
85silverbeast is offline   Reply With Quote
Old 12-30-2010, 10:00 PM   #7
69GMC910
MOTORHEAD!
69GMC910's Avatar
I just threw that 50 dollar price out there... I haven't actually called around yet. Thanks for all of your input and I'll be sure to post before and after pics when it's done!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 12-30-2010, 10:32 PM   #8
Tommy454
Tommy454's Avatar
If you are going to do it yourself take some pictures during disassembly for reference. If there is rust on the frame be sure to get as much off as possible (paint the frame if you can). Check the spring bed for any damaged springs or wires. Replace as necessary. It's also a good idea to add a layer of foam at this point to beef up the old cushions. Put the new upholstery in the cloths dryer for a while to soften it up (makes it easier to pull around the frames). Reassembly is pretty straight forward, refer to your pictures if needed.
Tommy454 is offline   Reply With Quote
Old 12-30-2010, 10:40 PM   #9
johnnypop
I did one myself as well... warming it up helps a ton as well as flipping the back inside out and rolling it on, that works good rather than trying to yank it all the way down.
johnnypop is offline   Reply With Quote
Old 12-31-2010, 01:08 AM   #10
ortega
Where did you guys get your seat covers from
ortega is offline   Reply With Quote
Old 12-31-2010, 01:42 AM   #11
69GMC910
MOTORHEAD!
69GMC910's Avatar
I got it from Brothers... It's an 82 and I went with the vinyl with velour inserts... The stock seat was all velour.. Thanks for the tips people!!! Keep them coming if you have more!!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
