Old 12-31-2010, 05:46 PM   #1
The--Tank
late model wheels on an 86
Will these 16" wheels fit on a 86 4x4? I found a good deal on some 90's model alum 6 lug wheels with new nittos that I would love to have, mainly for the tires but would run the wheels if they would work. I know i would have to modify the front caps for the hubs but is there anything else i'm missing?
1986 Chevy 1/2 ton 4x4 350 Auto Shortbed Fleetside
The--Tank is offline   Reply With Quote
Old 12-31-2010, 08:05 PM   #2
ortega
Re: late model wheels on an 86
i think they should fit if they are the same bolt pattern. i have some newer style rims on my truck, but my truck is 5 lug
ortega is offline   Reply With Quote
Old 12-31-2010, 08:52 PM   #3
TeXaS 86 C10
TeXaS 86 C10's Avatar
if its the same lug pattern they should match up, but you will have to get new lug nuts
1986 LWB C-10 305/th400 Daily Driver and beer runner
TeXaS 86 C10 is offline   Reply With Quote
Old 12-31-2010, 09:14 PM   #4
463
463's Avatar
http://www.roadkillcustoms.com/hot-r...ALL+MODELS+4X4
463 is offline   Reply With Quote
Old 12-31-2010, 11:38 PM   #5
Pop's C-10
Pop's C-10's Avatar
yes
Pop's C-10 is offline   Reply With Quote
Old 01-01-2011, 04:58 AM   #6
MTCK
MTCK's Avatar
Measure the center holes to ensure that they will fit over your hubs before you buy. I know that web page says they will fit, but I recall the newer trucks having a smaller center hole than our square bodies. Let us know if they fit.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-01-2011, 11:58 AM   #7
bmchevy1979
bmchevy1979's Avatar
that's what I thought and for the front you will have to open it through the wheel for the hub or does the center cap come off
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 01-03-2011, 11:11 AM   #8
The--Tank
Thanks for all the imput. I will check the center hub size. that is what I was most worried about.
Old 01-03-2011, 11:21 AM   #9
sailed2japan
Jonny
sailed2japan's Avatar
I'm pretty sure the offset is also different and the newer wheels have an extra inch of back spacing, I'm not 100% on this though.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 01-03-2011, 11:24 AM   #10
The--Tank
even if they are they should tuck in those big finders.
Old 01-03-2011, 12:24 PM   #11
spudz
spudz's Avatar
I have tryed this on a 4x4. The offset is a little off so they are tucked too far in and the fronts will not go on over the hub.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 01-03-2011, 12:51 PM   #12
The--Tank
So your saying the wheel won't fit up to the hub because of the offset correct. That is a problem.
Old 01-03-2011, 02:52 PM   #13
jkade
jkade's Avatar
The center hub hole is too small.. you would have to machine it out to make it work.
jkade is offline   Reply With Quote
Old 01-03-2011, 02:54 PM   #14
The--Tank
Thanks that's what I was needing to know
Old 01-03-2011, 03:08 PM   #15
spudz
spudz's Avatar
no I was saying the front hub will not fit threw the hole in the rim AND the offset is off. but can be corrected with spacers. I dont know what you would do about the hub fitting the hole tho.
Old 01-04-2011, 12:01 PM   #16
crazyforsummer
yes those wheels will fit on on an 80s and 70s trucks with a 6 bolt wheel pattern on the axels i have seen those era of trucks with the same wheels on them in calgary alberta when i use to live there
crazyforsummer is offline   Reply With Quote
