Old 01-20-2011, 08:10 PM   #1
502ss
502ss's Avatar
Airlift 5000 on a lowered 1 ton dually
I purchased an airlift 5000 kit for my lowered dually. The rear is lowered about 5". When I rough assembled the bag and brackets and placed on the leaf pack I am only going to get about 5.25" of space between the top and bottom bracket. The documentation requires the spacing to be between 5-8". Now I know I am inside the range but not by much. Actually when I put the bed back on I bet I will be below the 5" range. Has anyone used this kit before and what were you seeing for clearance? If it was like mine have you had any problems with the bags bottoming out?
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
Old 01-20-2011, 10:18 PM   #2
ERASER5
ERASER5's Avatar
Re: Airlift 5000 on a lowered 1 ton dually
Do you have room under the bed to raise the top bracket up farther? I realize it will be above the frame, but that can be addressed with more welding and fabbing.
What are you doing for air?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-20-2011, 11:24 PM   #3
502ss
502ss's Avatar
No room. The bed sits right on the frame. My only option would be to cut the floor out and cover it with sheet metal but I really don't want to do that. Air will be provided by airlift load controller
http://shop.airliftcompany.com/produ...Control_System
Old 01-21-2011, 06:00 PM   #4
502ss
502ss's Avatar
Ttt
Old 01-21-2011, 08:48 PM   #5
SCOTI
SCOTI's Avatar
Ride Techs set-up sits fore/aft of the axle tubes which give more room for the bags. Did you find a p/n on the bags yet?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-23-2011, 07:12 PM   #6
502ss
502ss's Avatar
Part number attached
Old 01-23-2011, 09:16 PM   #7
SCOTI
SCOTI's Avatar
Google search yields:
9.1 max height
2.3 min height
2270lb capacity @ 100psi
Their literature does not list ride height specifically so I would average the bags range & say you need 5.5-6.5" @ 'ride height'. Since you have more than 2.3" between the brackets, you should be ok.
Make sure that the 2.3" min bag height is not your only travel stop too.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-23-2011, 09:38 PM   #8
502ss
502ss's Avatar
9.1 max height
2.3 min height
I also looked up the part number and found the following PDF. Good news is if I have problems with the bags I can get one that has a smaller height but with almost the same capacity! Time will tell if the bags hold up!
http://www.airliftcompany.com/pdf/ai...ence_chart.pdf
