Old 02-11-2011, 12:36 PM   #176
Alvin
Never Done?
Alvin's Avatar
Re: No Limit '72 C-10
Rob, you've about got me talked into selling off my air ride stuff and switching to a handling-focused suspension. I'm interested in driving my truck more than anything and I feel the air ride adds complexity and possible problems that offset the cool factor when it's parked.
Needless to say I'm watching this post closely to see what other products you guys come up with.
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 02-11-2011, 12:59 PM   #177
67cheby
67cheby
67cheby's Avatar
aaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhhhhhhh!!!!!!!!!!! NNNNNNNNNNNNOOOOOOOOOOOOOOOOOO cant you have both...without SACRAFICING one or the other ???
67cheby is offline   Reply With Quote
Old 02-11-2011, 01:04 PM   #178
Alvin
Never Done?
Alvin's Avatar
I'm sure it's possible.. but I highly doubt it's within my budget!
Old 02-11-2011, 08:28 PM   #179
robnolimit
robnolimit's Avatar
don't give up just yet. Once I dial in the ride hieght I want, I plan on swapping the rear coils to bags. This is the only way I can hit my goal of good handling and tow a trailer. A spring is just a spring. And, an air spring has a naturally progressive spring rate. I guess the most important thing is getting the right bag at the right hieght to get the spring rate that you want. You can have it all, it just takes a little homework. To be honest, we fix air ride systems every week, and 99.9% of all problems can be tied to parts choice, or installation. Shocks and sway bars are still important.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 02-11-2011, 10:04 PM   #180
gringoloco
A guy with a truck
gringoloco's Avatar
Can you elaborate on the selection process for this? Is there published information on spring rates for 'bags, or will you be taking measurements by way of some sort of testing process?
Thanks in advance -Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 02-12-2011, 05:17 AM   #181
skoffice
skoffice's Avatar
Hey Rob, first of all THANK YOU, again, for all of this awesome info! It has been so much help, its unreal! Now, not trying to get off topic (though I'm sure someone else could benefit from the answer as well), but have you found the center of gravity point for JT yet? I'm trying to set up a 4 link in my buddy's truck, but it's not together yet so I really have no way of finding the CG. I know every truck is going to be different, but there should be a rough, general area of where it is on a SWB, truck lowered 3-6", small block, TH400. I read somewhere that the upper half of the bellhousing is a close estimate but that seems a little too far forward maybe? Any insight would be great!
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 02-12-2011, 12:40 PM   #182
robnolimit
robnolimit's Avatar
I'll see what I can do for ya this week.
Old 02-12-2011, 11:39 PM   #183
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Loving this build, keep it coming! Would drop spindles handle better vs. the cut springs?
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-13-2011, 02:09 AM   #184
gringoloco
A guy with a truck
gringoloco's Avatar
'Nother question while I'm bugging you: How much change in ride height did you see with the swap from the 6082 to the 6102? Any comparison shots wearing the same rolling stock?
Thanks -Chris
-Chris
Old 02-15-2011, 04:14 PM   #185
robnolimit
robnolimit's Avatar
In my opinion, I would always choose drop spindles overcut (short) springs as a first move. Then springs if needed. The 6102 spring is stiffer, 1015 lb/in. We cut 1/2 a coil. It is about a 1 1/2" drop spring that way. I like the ride, it is controlled but not stiff. By early spring we should have private label springs, but we need more testing to get the rate/hieght perfect. I swapped in some 4" drop rear springs - it had 2", and a 2" block, to get the back down some more. Well, its lower, but it rides like crap - too stiff. But it is close to the RH I'm after, so soon I think I will swap to air.
Old 02-15-2011, 08:54 PM   #186
Greywolf200
What were the spring rates for the old 2" dropped springs and the newer 4" springs? Thanks,
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline   Reply With Quote
Old 02-17-2011, 11:11 PM   #187
Hart_Rod
Hart_Rod's Avatar
Hey Rob any update or pictures of the rear sway bar setup? I'm interested in it as well as the brackets but I would like to see how it all fits together. Thanks,
R/
Hart_Rod is offline   Reply With Quote
Old 02-18-2011, 04:28 PM   #188
robnolimit
robnolimit's Avatar
Greywolf, I'll have to test the spring rates and let you know. - next week
HartRod, I'm still waiting on our revised sample bar. Hopefully tue or wed. I'll post up asap.
Old 02-18-2011, 06:29 PM   #189
usmcchevy
usmcchevy's Avatar
Thanks!
Build thread
LSx Swap FAQ index
Old 02-25-2011, 01:58 PM   #190
dirtball
dirtball's Avatar
Ttt
Brett
dirtball is offline   Reply With Quote
Old 02-26-2011, 12:38 PM   #191
robnolimit
robnolimit's Avatar
It's update time.Now we have a bent frame, and we can straighten it, but we found a pretty good (not perfect) bare frame for $300.00. Since we have a new cab, this seemed like a good move, as we can do more prep work, and still drive and test parts on the JT. We did some basic boxing, and welded in the front crossmember, and all frame crossmembers. The stock rear shock crossmember was bent, so we replaced it with a 1 1/2" tube, - we'll be using our new rear shoch mounts so we don't need them on the crossmember.
Old 02-26-2011, 12:42 PM   #192
67cheby
67cheby
67cheby's Avatar
why didnt you go ahead and notch the frame while you were at it ?? it will handle better a little lower wont it ??
Old 02-26-2011, 12:45 PM   #193
robnolimit
robnolimit's Avatar
we did flip the trailing arm mounts, to raise the anti-squat. The coating is called 'Raptor' liner, and its like a spray on bed liner. It's tough stuff, and easy to use. The cab was pressure washed, and sealed. We had to make raise the trans tunnel, so that was done and sealed up too.
Old 02-26-2011, 12:52 PM   #194
robnolimit
robnolimit's Avatar
We set the cab on using urathane mounts, and squared it all up nice. Next, we slid in our used 5.3 and boted it in. Now, I bought an ECE mount for the trans, and I like it a lot. It catches both the top and bottom of the frame, so it would help stiffen the chassis. But, someone welded in some tubes in our chassis, so the ECE mount won't go in. So we used one of ours. Urathane on the motor mounts, rubber on the trans. The oil pan hung down a bit, so we cut it off, shortened the pan 1 3/4", and added to the sump a bit forward. (i'll get some picts) The motor is as far back as we could get it in the stock firewall.
Old 02-26-2011, 12:58 PM   #195
robnolimit
robnolimit's Avatar
Just so you know, the stock exhaust manifolds would not fit. So, we got a set of the new Hedman 3/4 length for LS. When I was a kid, Hedman was not so great. But I have too tell you, these are NICE. 3/8" flanges, 16 gauge tubing, and nice collectors. Here's the best part, they fit GREAT! I can tell we'll be using a lot of these in the future.
Old 02-26-2011, 01:00 PM   #196
robnolimit
robnolimit's Avatar
Cool. looks I pulled one over on ya. Look at the rear kick. A bit more than a stocker. 4" more to be exact.
Old 02-26-2011, 01:00 PM   #197
67cheby
67cheby
67cheby's Avatar
i laughed after i posted that... "me telling you it would handle better lower" like i could tell you anything about handling...sorry
Old 02-26-2011, 01:01 PM   #198
67cheby
67cheby
67cheby's Avatar
i see....this young grasshopper still has alot to learn , note to self... look more open mouth less!!
Old 02-26-2011, 01:10 PM   #199
robnolimit
robnolimit's Avatar
We are using the stock ECU and harness. We used the instructions that are on the LS build threads. It took about 6 hrs to do. We sent the ECU out to be flashed for 75 bucks. Once everthing was in place, we hooked up the harness and it lit right off. we're makin good progress, and I'm excited.
Old 02-26-2011, 01:18 PM   #200
robnolimit
robnolimit's Avatar
Hey, you were right. We were just a step ahead. lol
1972 chevy, c-10, no limit engineering
