03-09-2011, 06:16 PM | #26 | |
Re: Wanting to bag truck but not lay frame questions
I feel it is worth-while to do whatever it takes to ensure the Panhard bar goes from the frame all the way across to the pass side T/A (or pass side of the rear end housing). That can be accomplished by buying a new aftermarket adj bar, or by modifying your exiting bar. If you go through the effort to make the factory bar longer, you might as well make it adj too.... It REALLY helps installation & set-up ease.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-09-2011 at 06:17 PM. |
03-09-2011, 07:12 PM | #27 |
cool, thanks bro!
Hey you coming to the meet and greet in Ft Worth Saturday?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-09-2011, 09:07 PM | #28 |
Didn't know about any such thing....
03-10-2011, 11:10 AM | #29 |
Ill PM you the info.
