03-04-2011, 08:01 PM | #1 |
Wanting to bag truck but not lay frame questions
Hey guys i am needing a little direction from you guys that have been there done that so to speak. I am looking for ideas on bagging my truck (1966 swb) but do not want to raise the bed floor. I see the porterbuilt stuff and really like it but not sure if its the right setup for me. Thanks in advance for guiding me in the right direction
03-04-2011, 08:08 PM | #2 |
Re: Wanting to bag truck but not lay frame questions
With a standard c-notch, you won't hit the bed unless you run a 3" block. Porterbuilts stage 2 rear would be perfect. Use that for the rear, replace your front springs with bags, get some drop spindles and you'd be low, easy to build and maintain, and would ride like a dream.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
03-04-2011, 08:23 PM | #3 |
A picture tells a thousand words, here is a pic of my rig replaced coils with bags no notch diff sits about 1/2 inch from the wood with no air. picture is a few years old but gives you an idea. hope this helps
03-04-2011, 08:50 PM | #4 |
I should have mine back on the wheels in about a week. I used 83 a arms and 2 1/2" drop spindles and bagged the truck. I did C notch the rear for room for the bump stops. Will have to see how it all goes back together.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-04-2011, 09:11 PM | #5 |
Airport Bum
I have a c notch and will bag the rear only.
nice and low but no airbag wallow.
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
03-04-2011, 09:12 PM | #6 |
Your truck is perfect dirtjumper63.
03-04-2011, 09:20 PM | #7 |
03-04-2011, 09:22 PM | #8 |
Please explain "airbag wallow", I think I mus tbe getting old..
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
03-04-2011, 11:17 PM | #9 |
Bags are pretty easy to do. There are a number of detailed write ups on this site with lots of pictures.
Sick truck dirtjumper.
03-05-2011, 03:19 AM | #10 |
Agreed. No such thing when done right.
03-05-2011, 11:03 PM | #11 |
its just $$$$$
03-05-2011, 11:15 PM | #12 |
Or no sway bar, T'd together, & no shocks..... Seems the 'shocks aren't neded w/air bags' theory is a common mis-conception.
03-06-2011, 12:04 AM | #13 |
its just $$$$$
I thought that was only on minitrucks??? Lol
Posted via Mobile Device |
03-06-2011, 05:31 AM | #14 |
hi my name is tino and i am new to this but ilove it to work on my 71 burban i like to lowering but i dont know where to start and how much to lower, i dont want to use a c- nocht and i want smooth ride, i need help to start
thank you guys |
03-07-2011, 02:38 PM | #15 |
Hah I thought that initially, it just seemed so natural the bags could hand the shock. They cant!
Trevor "You already said spite" |
03-07-2011, 04:20 PM | #16 |
Bags can 'handle' the shock; they can't control the motion that results.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-07-2011 at 04:20 PM. |
03-07-2011, 04:25 PM | #17 |
thank you
03-08-2011, 06:05 PM | #18 |
I bagged the rear of my 66 gmc just so I could control the rear height to my liking.
here is how the bags went in, the bags have 12" max height and I set the system up on the cheap $129.00 + 80.00 so 209.00 . No compressor on board yet , just air it up to height......If I need to lower the truck more I can take out the lower brackets . http://kieth.smugmug.com/Trucks/66-G...28723713_zsmuL I kept my original 6 cyclinder coils and they were already sitting low before the 350 went in, I think it will ride nice and not have cost a fortune. If it does not sit like I want in the front then I will change the front spindles out to -2-3.....Kieth |
03-08-2011, 06:06 PM | #19 |
testing
03-09-2011, 01:10 PM | #20 | |
needs more $$$
On my blazer, this is definetly the case (not a truck so maybe it's different). I cut out a hole for the pumpkin to come through since it was holding up the rear about 1/2-3/4" and I'm running 2" blocks and bags in the stock location in the rear.
1970 2wd Blazer |
03-09-2011, 01:45 PM | #21 |
1965 Chevy C10, 2005 4.8L/4l60
Keith,
So how do you fill up ur bags? by your calculations this is what I would like to do, install bags with the cups , then run lines to the rear roll pan and have valves there to fill up and read pressure, is that possible?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-09-2011, 04:24 PM | #22 | |
03-09-2011, 04:25 PM | #23 |
No reason you can't do it this way. I did the manual fill for almost 2yrs before getting a small tank/comp/manual valve set-up.
03-09-2011, 04:31 PM | #24 |
where do you get the bags i only have 2" block on the rear i dont know if i get lower coils or air bags and how ma ny inchs lower on the coils that goes to front and rear colis
03-09-2011, 04:36 PM | #25 |
Coils will be around $125.00/pr
Bags with cups and valves will be a little more, around $200.00 or so. Check with the board vendors here, they will get you a great deal. the thing that has held me back so far is I want to replace all the bushings and such at the same time. So getting all my $ upfront. Scotti, would I need an adj panhard bar?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 03-09-2011 at 04:37 PM. |
