Old 07-16-2003, 12:08 PM   #1
TIMSPEED
TIMSPEED's Avatar
[Pix] Flip Kit on a C10 SWB
Here's a few pictures I went out and took just now. This is for anyone wondering if they can do a Flip Kit in the back and not have to C-Notch. (I just removed the factory bumpstop bracket) The space between the axle/frame UNLOADED is 4"...
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 07-16-2003, 12:09 PM   #2
TIMSPEED
TIMSPEED's Avatar
Here's another picture, of the Shock Extenders...
See Them Here
Old 07-16-2003, 12:17 PM   #3
cochino12
It followed me home?
cochino12's Avatar
my kit (chassis tech) did not come with shock extenders? I wonder if I should have them?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-16-2003, 01:05 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
No flip kits come with shock extenders. IMO, shock extenders are needed with flip kits. When doing a flip, the shock angle changes a lot. Adding extenders will get some of it back to a more proper degree, besides giving you more shock travel.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 07-16-2003, 01:29 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I agree with swervin. My flip kit from a LONG time ago included them and I think they should include them also. Shocks should be mounted as close to 18 degrees as possible.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-16-2003, 02:07 PM   #6
apstguy
LED King
apstguy's Avatar
Doesn't that change the axle angle too? Shouldn't there be a spacer for the transmission to correct the angle?
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 07-16-2003, 02:37 PM   #7
swervin ervin
From what I gather, where you run into pinion angle trouble is when you don't lower it even. Say if you installed hangers only. This would tilt the pinion up and out of angle. Now if you go with a hanger/shackle combo, you are not changing the angle, only lowering it. What you are after is keeping the pinion angle the same as the tranny output shaft. So, as long as you don't roll the axle position from stock too much, you should be OK.
Correct me if I'm wrong guys.
Old 07-16-2003, 03:11 PM   #8
Captkaos
Captkaos's Avatar
Yes, and no. Typically you don't need to adjust the pinion angle on a flip. Most of the ones I have seen have the "engineered" the proper angle in there. I have had some people on the internet saying they needed shims, but I haven't. My pinion is usually around 3-4 degrees. You really don't want to change the angle on the transmission though, it will effect the engine/driveline angle. The pinion centerline and the drivetrain centerline should be parallel to each other for proper driveshaft phasing.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 07-16-2003, 03:48 PM   #9
Low83
Talking
I've had the flip kit on my Silverado for a long while without the C-notch and have never bottomed out the frame, the only time it has was when I had to load the bed with a load of rocks for a garden project, flip kit is the way to go, oh and I also got the shock extenders with my flip kit.
Low83 is offline   Reply With Quote
Old 07-16-2003, 03:52 PM   #10
cochino12
cochino12's Avatar
guess I better get some shock extenders.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-16-2003, 05:48 PM   #11
ItsNotABlazer
The full convertible guy
ItsNotABlazer's Avatar
I guess I better remove my bump stops AND get shock extenders lol.
Brad
2012 Kawasaki Vaquero (Lime Green)
2000 BMW 740iL
1995 Chevy ECSB riding on air
1975 GMC Jimmy 2WD lowered 4/6
1972 Chevy Trazer soon to be roadster
1965 Mustang 289/3 speed (friends dad bought it new)
1964 Chevy C10 (dad bought it new)
ItsNotABlazer is offline   Reply With Quote
Old 07-16-2003, 09:21 PM   #12
BaggedC10
Under construction!
BaggedC10's Avatar
Where did you get that DJM flip kit?!
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 07-16-2003, 09:39 PM   #13
bigd65
bigd65's Avatar
i put the hangers only, but i also replaced the 3 leaf with 4 leaf. do yall think i need to do something about the pinion angle thing.
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 07-16-2003, 10:17 PM   #14
swervin ervin
Jeff,
you only used the shackles, right? Dropping the rear of the leaf springs 2" really only drops the truck and inch or so. Not enough to worry about. Now if you did use hangers on the front, this will cause a weird pinion angle, IMO. I think I seen it somewhere, they tell you when you buy only hangers you might need to uses some shims to get the angle back right.
Old 07-17-2003, 12:03 AM   #15
78SilveradoSWB
78SilveradoSWB's Avatar
Arrow
FYI: I bought a DJM 5" flip kit from Stylin'Concepts and it included the shock extenders. I think the kit cost me $89 plus shipping.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 07-17-2003, 12:15 AM   #16
78chevstepside
78chevstepside's Avatar
I lowered my 78 4/6 with a notched frame. I also had to shorten my driveline 1" jay
78chevstepside is offline   Reply With Quote
Old 07-17-2003, 02:16 AM   #17
swervin ervin
The Western Chassis flip kit moves the axle back to take care of the driveline. It has an offset hole in the block for this purpose. Are you sure you put the block in the right way?
Old 07-17-2003, 01:35 PM   #18
apstguy
LED King
apstguy's Avatar
Seems I opened a can of worms. Guess that is what I am good at.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 07-18-2003, 12:02 AM   #19
78chevstepside
hmmmmm i will have to check to see if the block is placed correctly. I allready had the driveline shorten 1".
Old 07-18-2003, 12:26 AM   #20
TIMSPEED
TIMSPEED's Avatar
On my DJM kit, the hole was offset, to correct driveline angle. (To concur with Mike.)
See Them Here
