Old 04-03-2011, 10:01 PM   #26
stich626
Re: Waterpump?
it might,, a good lick of the mounting area with the area in the marker clearer..
stich626 is offline   Reply With Quote
Old 04-03-2011, 10:25 PM   #27
emil77
Re: Waterpump?
Thanks,
Emil
1972 Chevy C20
emil77 is offline   Reply With Quote
Old 04-03-2011, 10:32 PM   #28
leddzepp
Moderator
leddzepp's Avatar
Re: Waterpump?
Originally Posted by stich626 View Post
looking at his pic of the water pump on his engine there are spacers between the pump and block (iirc moroso made these)
he can run the short pump and spacers but thats 2 extra gaskets and 2 more places to leak.. or a long and toss the spacers
look at his pic's and the part withing the black marker..
if he runs the short pump without the spacers nothings going to line up,
If there are indeed spacers there (hard to tell, looks funny to me??) they are NOT 1 3/8" thick (the difference in length between short and long water pumps).
OP, your alternator is on the driver side, as it should be with a short water pump. Later year trucks (73-up) used a long water pump, and the alternator was on the passenger side. The pulleys/brackets used for short and long water pumps are different. I do not know if there are "spacers" on your water pump now or if that is just a funny looking way it was cast?? If they are spacers, it looks to me like if they were removed the water pump would hit the timing cover.
Take the pump off and take it to Autozone with you for comparison as Cdowns said way back when. Take the bolts to Home Depot or any hardware store and match them up to new ones. Case closed. Done deal. End of story.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-03-2011, 10:43 PM   #29
stich626
Re: Waterpump?
looks like a short, just can't make out what that (drivers side) leg thing is, spacer, casting line,,
Old 04-03-2011, 11:09 PM   #30
swamp rat
swamp rat's Avatar
Re: Waterpump?
All i see is a short water pump, no spacers between the pump and block, just the casting of the water pump, like was mentioned earlier you can take the old one off and take it with you, its good advice.
The only time any spacers between the pump and block might be needed is if the water pump actually compresses the timing cover so badly it would hit the timing chain/gears. Its very common that the covers touch, even have a little squish, or have very little space between them, the reason for a shim would be if the water pump was rebuilt they may surface grind the flange which would move the pump body closer to the engine block.
There is also fan/pully shims you can buy to align the pullys if nessasary.
The ground strap is mounted to a stud in your case, a stud in the block followed by a nut to secure the pump to the block, then another nut to secure the ground strap, you would be better off moving the ground strap to a hole on the head if one is avalable on the front surface. also plan on the stud comming out when you loosen the nut, it tends to happen a lot.
As mentioned remove the pump and take it with you, and take the bolts with to match them, there ether 3/8-18NC or 7/16-14NC, length i don't recall but would guess the
3/8's, there are both long and short lengths. Also, 2 of the bolts protrude into the water jacket so your going to have to seal the threads, some folks use black RTV, some use Perma-gasket or perma-tex.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-03-2011, 11:34 PM   #31
emil77
Re: Waterpump?
Great info, thank you. Any other advice you guys have on the removal/installation is appreciated.
Thanks,
Emil
1972 Chevy C20
Old 04-03-2011, 11:48 PM   #32
leddzepp
Moderator
leddzepp's Avatar
Re: Waterpump?
Swamp rats advice is spot on.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-03-2011, 11:49 PM   #33
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Waterpump?
Remove 4 bolts... knock old one off.
Scrape old gaskets off... put new gaskets between new pump and block, and bolt it on.
I use Gasgacinch to install "paper" gaskets.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-04-2011, 12:17 AM   #34
emil77
Re: Waterpump?
Hi Gary,
Don't I need to remove that belt/fan system also?
Thanks,
Emil
1972 Chevy C20
Old 04-04-2011, 12:50 AM   #35
swamp rat
swamp rat's Avatar
Re: Waterpump?
Yes, and drain the coolant, so while your in there its a good time to replace the thermostat and gasket and all the radiator and heater hoses and flush the cooling system too, may not be nessasary but it could avert problems down the road if they havent been changed out since who knows when..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-04-2011, 01:00 AM   #36
emil77
Re: Waterpump?
Thanks swamp.
Thanks,
Emil
1972 Chevy C20
Old 04-04-2011, 01:00 AM   #37
AustinScott
AustinScott's Avatar
Re: Waterpump?
emil77, just do us all a favor and remove the pump... then place it on a flat surface.. measure the pump...and get a new one from the parts store... what store... you pick...!!!!
WE all want to see a picture of a new pump under the hood of your truck...
Very simple, short pump, water pump gaskets, bolts & you are taking pictures of a finished job that we all can be proud of!!!
just buy a short pump and 2 water pump gaskets for the year of truck... Measure the bolts and you are on your way to giving us the pictures we all want to see....
you can do this!!!!
....Scott....
AustinScott is offline   Reply With Quote
Old 04-04-2011, 09:35 AM   #38
stich626
Re: Waterpump?
I 2nd the thermo stat and flush while open..
but this can balloon , then hoses then heater hoses then belts...and so on..
good luck..
Old 04-04-2011, 10:04 PM   #39
emil77
Re: Waterpump?
Thank you all for the great info.
Thanks,
Emil
1972 Chevy C20
Old 04-04-2011, 10:21 PM   #40
GASoline71
GASoline71's Avatar
Re: Waterpump?
Hi Gary,
I kinda figured you would have gathered that stuff had to come off first.
I also agree that a new t-stat and a flush.
Gary
Old 04-09-2011, 02:24 PM   #41
emil77
Re: Waterpump?
Ok, new water pump is in. New t-stat and a nice flush with new coolant added also. My friend came over and helped, so far so good. I took her for a quick test drive, no problems.
Thanks for all the help.
Thanks,
Emil
1972 Chevy C20
Old 04-09-2011, 03:19 PM   #42
AustinScott
Re: Waterpump?
nice!
now dont forget to snap a few pics, for all us "photo hounds!"
Old 04-10-2011, 02:48 AM   #43
emil77
Re: Waterpump?
It looks like we didn't tighten the water pump plug tight enough. I have coolant coming out from there. Whats the exact tool, size of tool I need for it? Also, what is the metal dowel looking thing for that comes with the new water pump?
Thanks,
Emil
1972 Chevy C20
Old 04-10-2011, 03:13 AM   #44
swamp rat
swamp rat's Avatar
Re: Waterpump?
That plug is in deeper than any i have ever seen, kind of unusual to me.
I just used teflon tape that you can purchase at any auto or hardware store and wrapped the plug about 3 times with the stuff, make sure you wrap the tape the correct direction so it won't come unwrapped when reinstalling it into the pump body. Its a thread sealant, any thread sealant that is compatable with antifreeze will work.
There may have also been a reduction bushing with both male and female threads to use if the plug is a bit smaller than the port on the water pump.
The plug uses an allen wrench or allen socket, cant tell the size from a picture but probably 1/2" ? You can measure it with a tape measure across 2 flats for proper size.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-10-2011, 02:45 PM   #45
emil77
Re: Waterpump?
There are additional plugs, do I need to put the smaller one first, then the bigger on top, sort of building it up?
Thanks,
Emil
1972 Chevy C20
Old 04-10-2011, 04:29 PM   #46
swamp rat
swamp rat's Avatar
Re: Waterpump?
No just use what threads together, you cant double stack 2 plugs cause the threads are tapered and you'd distroy the pump body. You only need a reducer sleve if the plug is way smaller than the threaded port on the water pump.
EDIT: Make absolutly sure that that plug is a pipe taper thread and not a SAE thread, that may be why it went in so far and may explaine why it didn't seal? Pipe taper threads have an interferance fit, SAE threads are the same diameter thru the length with no taper.. For reference look at the plug on ther lower port and note how it only went in just so far, thats from the tapered thread not letting it go to deep.
On my truck i use the upper port for my temperature sensor, its a pipe thread.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-10-2011, 06:35 PM   #47
emil77
Re: Waterpump?
Hmmm, ok, I will look more closely. I am using the plugs that came with the pump. There was 3 items in the box, this plug, then a smaller plug that threads into another one and a metal dowel looking thing.
Thanks,
Emil
1972 Chevy C20
Old 04-10-2011, 08:36 PM   #48
GASoline71
GASoline71's Avatar
Re: Waterpump?
When I bought my waterpump there were sets of plugs in there like you describe. You will need to thread the smaller one into the larger "adapter" and then thread that in to the hole.
I just ditched them all and bought a chrome plated plug from Moroso.
Gary
Old 04-11-2011, 01:21 AM   #49
emil77
Re: Waterpump?
Gary
Great, that's the info I was looking for. Thanks!
Thanks,
Emil
1972 Chevy C20
Old 04-11-2011, 10:57 PM   #50
emil77
Re: Waterpump?
I fixed it, I used a 3/4 drain plug with teflon tape on it. It fit perfectly into the hole and it's easier to take out if I ever have to then the standard drain plug.
Thanks,
Emil
1972 Chevy C20
