Waterpump?
Hi guys,
I need a new water pump for my '72 C20. I'm confused on some areas. One website shows options for a "long" or a "short" water pump. When I called Autozone, they have it in stock, but didn't know if it's short or long. Also, what size are the bolts that hold the water pump? I will be replacing those also.
Thanks, Emil 1972 Chevy C20 |
![]() Join Date: Sep 2003
Re: Waterpump?
if the back of the water pump touches the timing cover on the front of the motor it is short if there is a space it is long, 72 should be a short pump.
Last edited by Rooster's 67; 04-02-2011 at 01:40 AM. Reason: mis-stated the correct pump length (its late) |
Re: Waterpump?
Cool, what about the bolts?
Scrapper 1
Re: Waterpump?
most of these trucks had the small 283--327 water pumps Cus of the lining up of the pulleys.That's only if no body went in there and started changing pulleys Look and see if any of my pictures help .Now there not the best pictures but the last one is from a 1972 nova with a 307 that is a tall water pump If you have AC it might change it but on my 1971 Cheyenne it still has the small water pump But on that 307 look at the pulleys are they simler to what you have .or do you just have a single pulley on the water pump and on the crank you will have 2 single pulleys
Scrapper 1
Not always on my 1971 chevy 1/2 ton Cheyenne it has AC and it has the small water pump and so is my 1972 chevy 3/4 ton deluxe.It has a lot to do with the brackets they used on the trucks to line up the belts.Me i prefer the 327 Small water pump the brackets and the pulleys line up so sweet.And it depends on the long throw Alternator bracket on the driver side or used the small Throw alternator arm on the Car's on the driver side.it can get quit confusing.And you can tear up belts in a heart beat
Re: Waterpump?
Here are some pics of my engine:
Re: Waterpump?
a foolproff way to get the correct pump the first time is to take the old one with you when going to the store
#8 | |
1969 short box
Re: Waterpump?
Re: Waterpump?
Great, thanks for the info. They don't need a core, so I will try to take the old one to match it up.
Anybody know about the bolts?
Moderator
![]() Join Date: May 2007
Re: Waterpump?
A factory 72 truck should have the short water pump. Is your alternator on the driver or passenger side?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Scrapper 1
Re: Waterpump?
Just like i was saying I took more pictures to help you on your way The bib i talk about on heater core units only have it on the water pump and the intake Now the Ac modals have one on the intake and none on the water pump your radiator will be the spot where you get your hot water from
Re: Waterpump?
The alternator is on the drivers side.
#13 |
454 MAKES IT ROAR
Re: Waterpump?
Waterpump bolts are 2" long...
http://www.summitracing.com/parts/AR...3202/?rtype=10
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
#14 | |
Re: Waterpump?
#15 |
Re: Waterpump?
he has spacers on a short pump..
he should get a long pump bolts will be longer than 2" on a long |
#16 |
454 MAKES IT ROAR
Re: Waterpump?
What spacers? according to summit same bolt short or long pump.
#17 |
Re: Waterpump?
You guys are confusing me! Haha. Some say long pump, some say short, which one should I get???
#18 |
454 MAKES IT ROAR
Re: Waterpump?
Look at the illustration I posted it gives the sizes of the two types run a tape along side yours and see...it's either 5 5/8" short or 7" long. Your year truck should have short.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 04-03-2011 at 08:38 PM. |
#19 | ||
"I ain't nobody, dork."
Re: Waterpump?
All of the 67-72 trucks with a Small Block Chevy 283 thru 350 had short water pumps. You can get new water pump bolt kits either online or at an auto parts store. Just tell them you have a short water pump.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#20 |
Moderator
Re: Waterpump?
You have a short water pump.
#21 |
Re: Waterpump?
Thank you, thank you!
#22 |
![]() Join Date: Jul 2010
Re: Waterpump?
Why do you need new bolts? tha ole ones should be fine.
#23 |
Re: Waterpump?
looking at his pic of the water pump on his engine there are spacers between the pump and block (iirc moroso made these)
he can run the short pump and spacers but thats 2 extra gaskets and 2 more places to leak.. or a long and toss the spacers look at his pic's and the part withing the black marker.. if he runs the short pump without the spacers nothings going to line up, |
#24 |
Re: Waterpump?
I am weird like that, I like to replace everything and I'm missing one of the bolts.
#25 | |
Re: Waterpump?
Will a better pic of the water pump help clear up the short vs long issue?
