Old 04-08-2011, 05:10 PM   #1
Mattman2010
Mattman2010's Avatar
Removing windshield and rear window
How do you go about removing the windshield and rear window from the cab? Im starting to strip my cab down to paint.
Thanks, Matt
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 04-08-2011, 05:13 PM   #2
dv8customs
dv8customs's Avatar
Re: Removing windshield and rear window
The rear glass you can work from the inside. The gasket fits over a flange so start working the gasket up and over the flange. It isn't too hard to do, just get someone on the outside to catch it as it comes out. If you do the top first you can pull it out once you get about half way done.
dv8customs is offline   Reply With Quote
Old 04-08-2011, 05:20 PM   #3
Mattman2010
Sounds easy enough, what about the windshield?
Build Thread
Build Thread
Thread
Old 04-08-2011, 05:34 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
You going to be able to reuse your gaskets? Usually they are in pretty sad shape after 20 something years and will not be reusable. If this is the case, a good box knife helps a ton, as you can cut away the gasket really easy and the glass will literally fall out.
Otherwise, the front glass, remove the locking strip and work it out, fairly straight forward.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 04-08-2011, 05:45 PM   #5
Mattman2010
Alright, Thanks guys that should help me! And no, the gaskets need replaced, they are in poor shape.
Build Thread
Build Thread
Thread
Old 04-08-2011, 05:58 PM   #6
RandyP
RandyP's Avatar
Slide a blade in and cut the outer lip off of it then, front and back. Makes it so much easier, just have someone ready in case the glass is not stuck to the rubber (bet it is though). Otherwise some pressure from the inside will be needed to get it out.
My glass guy loved the 1 piece front and back glass weatherstrips (LMC), they have the locking strip made in to them. At first he fought it a tad, but after he was done he said it was actually easier for him.
