Old 04-13-2011, 07:00 PM   #1
tc4x4
tc4x4's Avatar
LMC bed cargo lamp
Has anyone bought one of these. If so I have a how to question. When you put the new rubber things in that have a small amount of metal threads in them, and then when you tighten them the rubber bulges on the inside of the wall of the cab making the light tighten down. So my rubber plug looking things are not doing what they are made to. They are pulling though and not tightening. HELP. SUGGESTIONS
tc4x4 is offline   Reply With Quote
Old 04-14-2011, 02:27 AM   #2
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Re: LMC bed cargo lamp
Ace hardware carries them in different sizes. Maybe get the next size up?
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 04-14-2011, 03:09 AM   #3
jitteryguy
GoatLube Experss
jitteryguy's Avatar
are they push'n in all the way down and are the thread's at the bottom ? I replaced mine with the LMC version with no issue's . the rubber bush'n should be stiff to push in but must be far enough for the rubber to swell inside befor it try's to push out.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 04-14-2011, 07:25 AM   #4
tc4x4
tc4x4's Avatar
Yes you are describing them and what i have accuratly but mine are not tight enough, they are swelling on the outside and pulling through. Ill check ACE today thanks.
Old 04-14-2011, 11:41 PM   #5
orbot
orbot's Avatar
Odd i got mine from LMC about a month ago and it went pretty good, lip on the outside then inserted the lil screw and tighten...
orbot is offline   Reply With Quote
Old 04-15-2011, 07:27 AM   #6
tc4x4
tc4x4's Avatar
Yes that is what I did also. Thinking one, two, three and done! But it kept pulling through and bulging on the outside of the can wall. So i went to ACE Hardware and got the exact same size rubber lock nut washer thingies but just about twice as long and came home and they tightened right up!
Old 04-15-2011, 02:59 PM   #7
jitteryguy
GoatLube Experss
jitteryguy's Avatar
they very could have package'd your with some insert's that were simply to short. glad to hear you got it work'd out though.
'85 1/2 ton CCSB
'92 S10 350/350
