#251 | |
Has more rust than truck...
Re: '72 Chevy SWB, Project Driver
#252 |
Still Learning
Nice work man. It looks like you are so close to having everything gathered up to make this baby run. I am gonna use an inline pump too I think. You remember what year the fuel regulator was added to the fuel rail? You are using the corvette filter/regulator right?
I am looking forward to getting started on my engine install. Getting burned out on this chassis build if you know what I mean. Once it's rolling than I will feel like I'm getting some where. |
#253 |
Thanks guys. Yes that WIX filter is the vette filter/reg. Returnless started in 04, vans were a little late in 05 or 06.
#254 |
Cool truck keep up the good work,Cruisin is only 6 months away... Maybe when both of our trucks are running we can do a lil cruising as im right across the bridge from you, And i can borrow a couple of your ideas....
1972 Custom 10 LWB 1973 V8 Vega wagon 1925 Model T Wrecker 1913 Model T Speedster http://s181.photobucket.com/albums/x...07/72skoolbus/ |
#255 |
Sure borrow away! More than likely the ideas you speak of were stolen from someone else
![]() Got the OBDII port mounted and finally got the radiator in for good with the trans cooler mounted and plumbed. |
#256 | |
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
#257 | |
#258 |
Yeah you should, one of our members said this is going to be our new name: Welcome to the ArkLaMissTexTennS.C. Louisiana Classic Truck club Where our motto is "As long as you like the truck you live close enuff"
#259 |
Lol.... Well ive lived here all of my life ,and im seeing names of places in la ive never heard of ,and by la i dont mean lower alabama as my friends call it that live there... an hour east and im in ala,and an hour west im in la.... Oh and im also James
#260 |
Hey from N.C.Just checking up on your build,i see you have made some head way & it's looking good,keep pictures coming
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, ![]() |
#261 | |||
![]() Quote:
![]() Quote:
Trans cooler mounted and plumbed. ![]() OBDII port, still got to hook it up. ![]() Threw on the plug wires and exhaust flanges with O2 sensors. ![]() Got the fuel line in. ![]() Still rusty, I'll clean it all up once I can back the truck out and pull the bed. ![]() Pump in there. ![]() List, 1, Wire fuel pump. 2, Wire OBDII port 3, Hook up MAF 4, Change oil+filter 5, Change trans filter+fluid 6, Add coolant 7, Enlarge hole in firewall and mount/plumb hydroboost 8, Turn key and pray! ![]() Also found out my drive shaft will work at its current length so all I need is a conversion U joint! |
#262 |
Bought all of the coolant, oil, fluid and filters. Now I just need some time to work
#263 |
![]() Join Date: Dec 2007
scribed.........
You are close! |
#264 |
Still Learning
Looking good buddy!
#265 |
ahhhhh! can smell the burnt hydrocarbons all the way over hear in iraq.... no wait thats jp8 from the helicopters dang it!! looks like your so very close will there be video (hint hint) i need to hear the rumble of an american v8 toyota diesels just dont get it
#266 |
It runs!!!!!
![]() I have a video, but need to figure out how to post it. |
#267 |
For open manifolds, she isn't that loud. No coolant so I didn't let it run long. Air intake is VERY temporary
#268 |
must feel great to hear it purr.i cant wait to be at that stage
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 |
#269 |
![]() Join Date: Apr 2005
Sounds great! What software package did you use and where did you get it?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#270 |
Thanks! She smooths out the more it runs. The software is ElmScan, its a scan tool that allows you to view data and read and clear codes. It doesn't have "tuning" capability like HPtuners or EFI live.
More info on it http://www.scantool.net/elmscan5-compact.html I bought it on amazon for $40 ![]() |
#271 |
just read the whole build. Awesome!!!!!!
#272 |
sounds great
#273 | |
#274 |
Grandpa in the rustmobile...
Very very nice..
When do you think she'll be on the road?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#275 |
Thanks everyone. The tune was a mail tune by Black Bear Performance, great customer service. I hope to have it on the road by the end of May at the latest. Then I can start working on it like I originally intended(small weekend projects)
![]() List for drivable. Fill with coolant Make push rod spacer for master cly Install/rebuild steering column and shift linkage Clean/paint driveshaft and press in U joints Figure out a air intake Install hood Mount TAC and gas pedal Clean up wiring in cab, behind motor and by computer. And I better get some exhaust on it ![]() |
