Old 04-19-2011, 11:15 PM   #251
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: '72 Chevy SWB, Project Driver
Originally Posted by fishingjred73 View Post
Did that hydroboost come out of the van you got the motor from? And have you seen these http://67-72chevytrucks.com/vboard/s...d.php?t=347480 http://www.67-72chevytrucks.com/vboa...d.php?t=347484
Hydroboost came out of the same van the engine did. I have seen Captinfab's adapters, nice stuff! However his adapters place the hydroboost unit about 1.5" farther from the firewall and my push rod was barely long enough to reach the pedal even with the extended end. Plus this plate and end were $25 shipped....and I'm cheap
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-19-2011, 11:52 PM   #252
mcbassin
Still Learning
mcbassin's Avatar
Nice work man. It looks like you are so close to having everything gathered up to make this baby run. I am gonna use an inline pump too I think. You remember what year the fuel regulator was added to the fuel rail? You are using the corvette filter/regulator right?
I am looking forward to getting started on my engine install. Getting burned out on this chassis build if you know what I mean. Once it's rolling than I will feel like I'm getting some where.
Old 04-20-2011, 11:13 AM   #253
usmcchevy
usmcchevy's Avatar
Thanks guys. Yes that WIX filter is the vette filter/reg. Returnless started in 04, vans were a little late in 05 or 06.
Build thread
LSx Swap FAQ index
Old 04-21-2011, 10:34 PM   #254
skoolbusyeller72
skoolbusyeller72's Avatar
Cool truck keep up the good work,Cruisin is only 6 months away... Maybe when both of our trucks are running we can do a lil cruising as im right across the bridge from you, And i can borrow a couple of your ideas....
1972 Custom 10 LWB
1973 V8 Vega wagon
1925 Model T Wrecker
1913 Model T Speedster
http://s181.photobucket.com/albums/x...07/72skoolbus/
skoolbusyeller72 is offline   Reply With Quote
Old 04-21-2011, 11:32 PM   #255
usmcchevy
usmcchevy's Avatar
Sure borrow away! More than likely the ideas you speak of were stolen from someone else We really need to have a board meet this year during crusin. I tried to get one going last year, but failed lol.
Got the OBDII port mounted and finally got the radiator in for good with the trans cooler mounted and plumbed.
Build thread
LSx Swap FAQ index
Old 04-21-2011, 11:48 PM   #256
fishingjred73
fishingjred73's Avatar
Ben you should check this out. http://louisianaclassictruckclub.fre...enings-f3.html There's usually about 12 or so guys that go to CTC.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 04-22-2011, 12:10 AM   #257
usmcchevy
usmcchevy's Avatar
Ya, there were tons of guys and trucks here...I just didn't meet any I'll have to sign up over there.
Build thread
LSx Swap FAQ index
Old 04-22-2011, 02:06 PM   #258
fishingjred73
Yeah you should, one of our members said this is going to be our new name: Welcome to the ArkLaMissTexTennS.C. Louisiana Classic Truck club Where our motto is "As long as you like the truck you live close enuff"
James
Member of
Old 04-22-2011, 05:12 PM   #259
skoolbusyeller72
Lol.... Well ive lived here all of my life ,and im seeing names of places in la ive never heard of ,and by la i dont mean lower alabama as my friends call it that live there... an hour east and im in ala,and an hour west im in la.... Oh and im also James
1972 Custom 10 LWB
1973 V8 Vega wagon
Old 04-22-2011, 05:22 PM   #260
RCbowtie69
RCbowtie69's Avatar
Hey from N.C.Just checking up on your build,i see you have made some head way & it's looking good,keep pictures coming
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 04-22-2011, 11:35 PM   #261
usmcchevy
usmcchevy's Avatar
I'll get signed up soon.
I've been here for just about three years and I still pronounce names to local towns wrong
Thanks!
Trans cooler mounted and plumbed.
OBDII port, still got to hook it up.
Threw on the plug wires and exhaust flanges with O2 sensors.
Got the fuel line in.
Still rusty, I'll clean it all up once I can back the truck out and pull the bed.
Pump in there.
List,
1, Wire fuel pump.
2, Wire OBDII port
3, Hook up MAF
4, Change oil+filter
5, Change trans filter+fluid
6, Add coolant
7, Enlarge hole in firewall and mount/plumb hydroboost
8, Turn key and pray!
Also found out my drive shaft will work at its current length so all I need is a conversion U joint!
Build thread
LSx Swap FAQ index
Old 04-24-2011, 12:29 AM   #262
usmcchevy
usmcchevy's Avatar
Bought all of the coolant, oil, fluid and filters. Now I just need some time to work
Build thread
LSx Swap FAQ index
Old 04-24-2011, 01:05 AM   #263
5150.4.67
scribed.........
You are close!
5150.4.67 is offline   Reply With Quote
Old 04-24-2011, 02:03 PM   #264
mcbassin
Still Learning
mcbassin's Avatar
Looking good buddy!
Old 04-25-2011, 01:22 AM   #265
68greg
ahhhhh! can smell the burnt hydrocarbons all the way over hear in iraq.... no wait thats jp8 from the helicopters dang it!! looks like your so very close will there be video (hint hint) i need to hear the rumble of an american v8 toyota diesels just dont get it
68greg is offline   Reply With Quote
Old 04-29-2011, 04:46 PM   #266
usmcchevy
usmcchevy's Avatar
It runs!!!!!
I have a video, but need to figure out how to post it.
Build thread
LSx Swap FAQ index
Old 04-29-2011, 05:52 PM   #267
usmcchevy
usmcchevy's Avatar
For open manifolds, she isn't that loud. No coolant so I didn't let it run long. Air intake is VERY temporary
Build thread
LSx Swap FAQ index
Old 04-29-2011, 07:51 PM   #268
(joey)
(joey)'s Avatar
must feel great to hear it purr.i cant wait to be at that stage
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline   Reply With Quote
Old 04-29-2011, 11:04 PM   #269
Hart_Rod
Hart_Rod's Avatar
Sounds great! What software package did you use and where did you get it?
Hart_Rod is offline   Reply With Quote
Old 04-29-2011, 11:49 PM   #270
usmcchevy
usmcchevy's Avatar
Thanks! She smooths out the more it runs. The software is ElmScan, its a scan tool that allows you to view data and read and clear codes. It doesn't have "tuning" capability like HPtuners or EFI live.
More info on it
http://www.scantool.net/elmscan5-compact.html
I bought it on amazon for $40
Amazon.com: ElmScan 5 Compact USB OBD-II Scan... Amazon.com: ElmScan 5 Compact USB OBD-II Scan...
Build thread
LSx Swap FAQ index
Old 04-30-2011, 01:52 AM   #271
wtchop
wtchop's Avatar
just read the whole build. Awesome!!!!!!
wtchop is offline   Reply With Quote
Old 04-30-2011, 10:07 AM   #272
68greg
sounds great
Old 04-30-2011, 11:45 AM   #273
Hart_Rod
Hart_Rod's Avatar
More info on it
Thanks. Who's going to tune your computer?
Old 04-30-2011, 12:29 PM   #274
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Very very nice..
When do you think she'll be on the road?
John
1999 Toyota Tacoma 4x4
Old 04-30-2011, 02:19 PM   #275
usmcchevy
usmcchevy's Avatar
Thanks everyone. The tune was a mail tune by Black Bear Performance, great customer service. I hope to have it on the road by the end of May at the latest. Then I can start working on it like I originally intended(small weekend projects)
List for drivable.
Fill with coolant
Make push rod spacer for master cly
Install/rebuild steering column and shift linkage
Clean/paint driveshaft and press in U joints
Figure out a air intake
Install hood
Mount TAC and gas pedal
Clean up wiring in cab, behind motor and by computer.
And I better get some exhaust on it
Build thread
LSx Swap FAQ index
