Old 06-28-2011, 05:53 PM   #1
BossHogg69
motor exploder
BossHogg69's Avatar
Core support rust - fixable???
I did a quick search but couldn't find much in regard to fixing rust on a core support, namely the area under the battery, which is where my problem is. I don't want to buy an aftermarket one, because from what I've found and read here, they don't fit well. The pics below are what I'm dealing with. Other than the pics, everything else is solid, its just the area under the battery tray that has issues. Any ideas on fixing this? The threaded bolt holes are still there, but the flat area around them is pretty thin, and the lip around the edges is about gone. I have a welder handy and don't mind taking on this challenge, just wanted to check and see if anyone has done this type of repair before and how it turned out. Thanks in advance for any help and/or advice!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-28-2011, 06:06 PM   #2
70cst
70cst's Avatar
Re: Core support rust - fixable???
I wonder if a good used core support would be a better way to go....Just a thought and a bump...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-28-2011, 06:24 PM   #3
john
member #16
john's Avatar
Brothers has a patch for that area.
http://www.brotherstrucks.com/prodin...number=RSP72RH
john is offline   Reply With Quote
Old 06-28-2011, 06:31 PM   #4
70cst
70cst's Avatar
There you go ...
Old 06-28-2011, 06:37 PM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
Thanks john & 70cst, that's why this board is the best! I know what I'll be doing this weekend...
Adam
Old 06-29-2011, 08:46 AM   #6
eagleuh1
eagleuh1's Avatar
Its fixable.I did mine before the brothers patch showed up. Pretty easy fix. The patch makes it easier. Good luck. Jim
Sorry, couldn't find pic of it repaired.
eagleuh1 is offline   Reply With Quote
Old 06-29-2011, 08:48 AM   #7
eagleuh1
eagleuh1's Avatar
Closest I could find, Sorry.
Old 06-29-2011, 10:31 AM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
eagleuh1 - What did you end up using to patch yours up? Your engine bay looks pretty nice, just from what can see in that little snapshot.
I was just over in Russellville this past sunday visiting the in-laws...
Adam
Old 06-29-2011, 12:08 PM   #9
eagleuh1
eagleuh1's Avatar
I made a piece from some scrap sheetmetal I had of the same thickness as original. I just copied the shape of the original, cut it out and bent it up to match the original piece. Then tacked and spot welded it in place, checked the fit and finished tigging it in. Much better than aftermarket core supports. The rest of support was in excellent shape. Wished I had taken pics of piece as being fabricated. Good luck. Jim
Old 06-29-2011, 12:20 PM   #10
eagleuh1
eagleuh1's Avatar
Heres a little diagram, hope it helps. Jim
Old 06-29-2011, 07:02 PM   #11
my67c20
Been there. Tried to buy the part from brothers, it was out of stock. Bought a piece of sheet metal from Farm and Fleet bent it up, little bit of welding, picked up some weld nuts from Ace, little bit of paint and just like new
my67c20 is offline   Reply With Quote
Old 06-29-2011, 07:06 PM   #12
bondo510
good job!
bondo510 is offline   Reply With Quote
Old 06-29-2011, 07:59 PM   #13
BossHogg69
motor exploder
BossHogg69's Avatar
That looks really good! I ordered the Brother's patch piece a couple days ago, so hopefully it works out okay. Keep the pics coming guys, I like have some inspiration!
Adam
Old 06-29-2011, 11:36 PM   #14
Boog
laying low
Boog's Avatar
I'm needing to do the same thing to mine. I actually went to Petit jean with that on top of my list of things to pickup. No one there sold them. Guess I'll be ordering from Brothers too.
Boog
Old 06-29-2011, 11:42 PM   #15
BossHogg69
motor exploder
BossHogg69's Avatar
I looked for one around here too, and didn't find anything. Seems like good parts for 'our' trucks are kinda rare in these parts... But I do see beat up, rusted up, used up stuff all the time!
Adam
Old 06-30-2011, 01:18 PM   #16
eagleuh1
eagleuh1's Avatar
Its not to hard to make the part. Its hidden so well, you don't even have to do that good a job. LOL. I had a machine shop do the 90 deg bends on mine, but i cut it up and welded it. Wish I had a sheet metal break, but I got a lot of wish I hads. Sure beats replacing the whole core support if yours is in fair shape otherwise. Good luck. Jim.
Old 06-30-2011, 01:55 PM   #17
my67c20
Thanks for the comments.
Another problem i had was brothers will list it as back ordered and not actually have ordered them so you could be waiting longer than having a sheet metal shop bend you up some 16ga and just hammer fitting it the rest of the way.
Old 08-25-2011, 02:06 AM   #18
BossHogg69
motor exploder
BossHogg69's Avatar
Finally got around to finishing up what I started. I didn't take any pics of what I cut out, but you get the idea from the pics. I just drilled some holes in the patch piece and plug welded it and dressed it with a 60 grit flap disc. Along the bottom, already had holes from drilling out the spot welds, so I plug welded the patch piece using those holes. I tried to stitch weld it on the bottom too, but I shouldn't have, since it looks like crap. Good thing no one will see my pigeon poop welding down there! Btw, this is the first time I've ever done any welding on sheetmetal. I quickly figured out I don't have the patience for it.... I will say the Brother's patch didn't need much trimming, since the rotten spot I had was pretty big. It was a pretty simple fix overall.
Adam
Old 08-25-2011, 10:31 PM   #19
eagleuh1
eagleuh1's Avatar
Good job on the repair. Looks real nice. What did the Brothers patch set you back? Jim
Old 08-25-2011, 11:20 PM   #20
BossHogg69
motor exploder
BossHogg69's Avatar
If I'm not mistaken, it was right at $50, which is high when you consider its really only about $5 worth of metal, but it had the nuts welded in already, and fit well. It took me a little over an hour to do, including cutting out the rotten spot.
Adam
Old 08-26-2011, 10:03 PM   #21
stsalvage
Scrapper 1
stsalvage's Avatar
THAT DAM BATTERY BOX And acid it has tore up more trucks then anything.I bought this truck for 650.00 5 years ago and its pretty straight.Its fully loaded just found all the factory AC brackets and got them mocked up.I was looking into buying a new core support then one just drop out of the sky with a wheel well and battery box for a AC truck and same year YAA here are the pic's
stsalvage is offline   Reply With Quote
Old 08-26-2011, 10:07 PM   #22
stsalvage
Scrapper 1
stsalvage's Avatar
newer core support for 50.00 with battery tray and wheel well
Old 08-26-2011, 10:08 PM   #23
stsalvage
Scrapper 1
stsalvage's Avatar
Number 3
Old 09-11-2011, 02:13 PM   #24
Boog
laying low
Boog's Avatar
Adam thanks for the pics. I've been wanting to see a pic of the Brothers patch installed. That looks good. It'll do just fine for mine.
And Jim I appreciate your fab skills too. I just don't have the patience for it.
Boog
Old 09-11-2011, 07:00 PM   #25
Boog
laying low
Boog's Avatar
I just ordered a patch panel and radiator cover from Brothers. They have another sale going on until Oct 31. No the patch panel is not one of the sale items....
Boog
core support, radiator support, rust
