#18 |
motor exploder
Re: Core support rust - fixable???
Finally got around to finishing up what I started. I didn't take any pics of what I cut out, but you get the idea from the pics. I just drilled some holes in the patch piece and plug welded it and dressed it with a 60 grit flap disc. Along the bottom, already had holes from drilling out the spot welds, so I plug welded the patch piece using those holes. I tried to stitch weld it on the bottom too, but I shouldn't have, since it looks like crap. Good thing no one will see my pigeon poop welding down there! Btw, this is the first time I've ever done any welding on sheetmetal. I quickly figured out I don't have the patience for it.... I will say the Brother's patch didn't need much trimming, since the rotten spot I had was pretty big. It was a pretty simple fix overall.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() Use the SEARCH function on this forum - it is your friend!! |
| Bookmarks |
| Tags |
| core support, radiator support, rust |
