#26 | |
Still Learning
Re: Where did you buy your brake line kit? Did you like?
![]() the kit is 11 pieces and I would like to mount them in the "correct" location if you know what I mean. |
#27 |
Laid Back
![]() Join Date: Apr 2010
If you need any help mike I can come help you I have done more than my fair share of these
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
#28 | |
Still Learning
The biggest problem is figuring out where all the bends should fit. I'm working on getting some pics from a member. Apparently, I forgot to order a few things too.....dumb |
#29 |
motor exploder
rear line pics. In the third pic you can see where I had to rotate the line to go around my rear swaybar bracket. It usually goes in the little clip on the axlehousing that is visible right beside the swaybar bracket that I used. Sorry, the pics are a little dark. This is a POL kit, if anyone cares. Also, I believe the hardlines run right into the wheel cylinders on a stock drum application. I have rear discs, so I had to use SS flex lines to reach the calipers (not shown).
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 07-01-2011 at 01:01 AM. |
#30 |
motor exploder
front pics, CPP kit. I buy what's on sale...
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 07-01-2011 at 12:56 AM. |
#31 |
motor exploder
couple more pics of what I was talking about on the rearend. Sorry the pics are only thumbnail size, my computer is p!$$!ng me off right now with loading pics.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
