Old 07-20-2011, 04:53 AM   #1
Mcgwirejh
leaf spring help
i bought 1997 chevy z71 someone put a 14 bolt rear end under the truck arent these truck suppose to coem with 10 bolt also i think someone put add leafs in the back not sure how many leaf springs are suppose to be on each side on factory z711997 model
Mcgwirejh is offline   Reply With Quote
Old 07-20-2011, 08:31 PM   #2
89chevsj
error 404
89chevsj's Avatar
Re: leaf spring help
should be 3 leafs and an overload. total of 4 the shortest being the overload and it apperas to be almost straight. if you could post a picture i could tell you exactly whats going on. also 1/2 ton?
89 Chevy swb 350 "SJ" DD turned parts truck. SOLD
90 Chevy ext cab loooongbed. "storm trooper" Rust In Peace.
06 Kia sorento wife's car
06 charger srt8 "lucifer" my toy
'12 Kia optima
89chevsj is offline   Reply With Quote
Old 07-20-2011, 09:01 PM   #3
Mcgwirejh
it is 1/2 ton truck
Old 07-21-2011, 07:59 PM   #4
89chevsj
error 404
89chevsj's Avatar
your first pic looks fishy. that one on the bottom that looks bent. is that a leaf or somthing else. if its not a leaf i would bet those are stock leafsprings. if it is a spring, get rid of it there shouldn't be a longer spring after your overload. there was a 3:1 4:1 (3 leafs one overload and 4 leafs 1 overload respectively) what sparked you interest? rideheight/quality?
'12 Kia optima
Old 07-21-2011, 08:39 PM   #5
Mcgwirejh
that one bent on the very bottom i was told thats a helper spring so i have 4 leafs and overload then with helper spring
Old 07-21-2011, 09:20 PM   #6
mountie
mountie's Avatar
If you carry a bunch of weight all the time, the helper works....
I had a helper leaf. ( my truck had a big camper on it before I bought it). I took the helper off to lower it and soften the ride.
my truck has a HD 3/4 ton. ( Camper Package)
That helper was over-kill for my use.
mountie is offline   Reply With Quote
Old 07-21-2011, 09:34 PM   #7
Mcgwirejh
oh i dotn even carry anything can i take the helper off then
Old 07-21-2011, 10:42 PM   #8
mountie
mountie's Avatar
Yea.. remove it. It was a big difference when I took mine off.
It's an add-on.... so nothing will change except for the ride. Still firm as normal - less bouncy.
Old 07-22-2011, 08:43 PM   #9
89chevsj
error 404
89chevsj's Avatar
actually removing the helper makes a smoother ride. i couldn't get my leafsprings off. i need to chang them because it was dropped with a shackle and by removing some leafs. but it was seized on so i couldn't. threw a 2 inch block under it for now.
'12 Kia optima
Old 07-22-2011, 10:49 PM   #10
Mcgwirejh
was wondering did they put add leaf under my truck cause i have 4 leafs and 1 overload
Old 07-23-2011, 10:54 PM   #11
89chevsj
error 404
89chevsj's Avatar
yes they added the helper. it can be easily removed.
'12 Kia optima
