Old 07-23-2011, 08:24 PM   #1
gotchamel
Overflow tank?
Where is the correct location for a coolant recovery tank on a 69 c10{if it had 1?}.Got a aftermarket 1 but does not seem to really fit anywhere practical.
gotchamel is offline   Reply With Quote
Old 07-23-2011, 08:28 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Overflow tank?
Didn't have one from the factory. Some people put them on the radiator core support and others put them on the opposite fender from the window washer bottle.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 07-23-2011, 10:07 PM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Overflow tank?
i just bought one from jegs with the bracket im going to mount mine where the battery used to be
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-24-2011, 12:21 AM   #4
elf w/capital T
Re: Overflow tank?
i may be wrong but ....front portion of the passenger wheel well 'tub'... sits right behind the battery...
elf w/capital T is offline   Reply With Quote
Old 07-24-2011, 03:07 AM   #5
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Overflow tank?
Some pictures of peoples would be good as I've just bought one from summit racing and haven't got a clue where to mount it, the current bottle (old coolant bottle!) is tucked in the passenger fender
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 07-24-2011, 03:32 AM   #6
dubds10
Stalker Nate
Re: Overflow tank?
Various on the truck but it's an option from what I've seen. Not mandatory on any of them. Typically it bolts to either the driver's front fender or passenger side front area. Just after the battery beside the wheel well. I've found them on both sides from the factory.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 07-24-2011, 04:23 AM   #7
Steve Hafner
Steve Hafner's Avatar
Re: Overflow tank?
It would be a lot easier to have it near the cap, on the passenger's side, so you wouldn't have to run the hose across the top of the radiator.
Here are a few that I've saved:
Life is short . . . we only have, right now.
My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526
Steve Hafner is offline   Reply With Quote
Old 07-24-2011, 06:43 AM   #8
dmack91
dmack91's Avatar
Re: Overflow tank?
I got a universal one from NAPA and it fit between the battery and the pass. fender (just barely).
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 07-24-2011, 09:21 AM   #9
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Overflow tank?
The optional/dealer installed tank, was typically mounted to the radiator support on the driver's side, just about where a second battery tray would mount. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 07-24-2011, 11:40 AM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Overflow tank?
i've only seen proof of one factory one, and it was a gov truck. All the rest were dealer installed, or more likely, parts store stuff. You can still find them that look much like the dealer parts pieces.
Old 07-24-2011, 12:26 PM   #11
68gmsee
Active Member
68gmsee's Avatar
Re: Overflow tank?
Two options on my GMC. The second pic is what I have right now. Spent $10 at Lowes on it.
68gmsee is offline   Reply With Quote
Old 07-24-2011, 12:36 PM   #12
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Overflow tank?
I was wondering if anyone had put theres the front side of the core support as I was thinking about mounting mine there, Looks like a goer, mines a black Summit 1 quart job so won't be too obvious from the grille.
Phil
'67 C10 long fleet.
Old 07-24-2011, 06:50 PM   #13
71 super
71 super's Avatar
Re: Overflow tank?
Here is a picture of the dealer installed GM tank. It is identical to the version Andy mentioned on the government truck. I bought this one several years ago it was NOS sealed in the GM box. It mounts on the core support just above the horn as trevor stated in about the same location as the aux. battery tray. I also included some pictures of the truck just because
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 07-24-2011, 07:26 PM   #14
chewychevy67
Re: Overflow tank?
I to have a nos set up and the instruction sheet shows it goes right where 71 super has his.
chewychevy67 is offline   Reply With Quote
Old 07-24-2011, 07:30 PM   #15
dukcaln
dukcaln's Avatar
Re: Overflow tank?
I find myself in need of one too, didn't have one when i bought the truck..... so you can purchase one from napa over the counter?
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 07-24-2011, 09:20 PM   #16
my67c20
Re: Overflow tank?
Bought one from summit. Saw another post that someone used a metal water bottle, another that they used one of the new aluminum beer pints with the screw on lid. Here is some pictures of my installation. Mounted off the factory battery bracket.
my67c20 is offline   Reply With Quote
Old 07-24-2011, 10:56 PM   #17
dubds10
Stalker Nate
Re: Overflow tank?
I didn't know these were so rare lol Most my trucks have had one hahaha
Old 07-25-2011, 01:42 PM   #18
71 super
71 super's Avatar
Re: Overflow tank?
The GM version is pretty hard to find. The others pictured are parts store units and available almost every where. The GM unit is pretty big and has a dedicated bracket/holder to support on all sides as well as the bottom.
Old 07-25-2011, 02:17 PM   #19
gotchamel
Re: Overflow tank?
The one I bought is from LMC,it will not fit on the overflow side of the radiator.It will have to go on the drivers side and route hose.It seems rather oversize?
Old 07-25-2011, 05:17 PM   #20
original-71
///Relaxed Atmosphere
original-71's Avatar
Re: Overflow tank?
71 super thats one beautiful truck, can i see more pics of that overflow? and where did you buy it from if you dont mind me asking? i want something close to stock also.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 07-25-2011, 09:43 PM   #21
dubds10
Stalker Nate
Re: Overflow tank?
I got a few of the GM ones so they aren't rare to me Never seen any other kind on any of the trucks I've bought. And to think I was just going to throw them out cause I figured everybody had one
Old 07-25-2011, 10:22 PM   #22
71 super
71 super's Avatar
Re: Overflow tank?
Original 71 I got the tank off of ebay a couple of years ago. Let me look back through some photos and see if I have more of the tank.
Old 10-30-2011, 04:45 AM   #23
karl
karl's Avatar
Re: Overflow tank?
The one i was just overcharged for($28) by LMC is a pc of Taiwan crap. Only one of the holes lined up and the cap wont snap on. Even the plastic is paper thin unlike the originals. Supposed to be a factory replacement for my 75 C10. The last one i bought from Classic Ind. was better made. I think this is the last one i will buy. Next time i will make something. Poor quality products fall by the wayside.
karl is offline   Reply With Quote
Old 10-30-2011, 09:37 AM   #24
Ironhorse
Ironhorse's Avatar
Re: Overflow tank?
Don't have a pic of it but I installed mine on the passenger side just aft of the battery. Used a w/s washer tank and bracket. Looks stock and matches the factory washer tank on the driver's side. Just don't get confused and put anti-freeze in the driver's side tank.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 10-30-2011, 12:33 PM   #25
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: Overflow tank?
I used a washer fluid bottle and mounted mine next to the battery. It works and looks stock to those who don't know.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
