Old 09-05-2011, 01:47 PM   #1
kcfirstbuild
moog ball joint Castle Nut Torque
i'm working on my 68 c10 and I misplaced my instructions for my moog upper and lower ball joints. I am not sure of the torque specs on the castle nuts. If i would get some help right away that would be great. So far on here I found 50 ft for the upper and 90 for the lower. but im not sure if thats for moog or just OEM.
kcfirstbuild is offline   Reply With Quote
Old 09-05-2011, 02:31 PM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: moog ball joint Castle Nut Torque
I didn't bother about torque specs with mine, I just tightened them till the the nut wouldn't go any further and I could get the cotter pin in.
Not sayin that's the right thing to do, it just seemed like a common sense approach for me.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 09-05-2011, 03:31 PM   #3
Autoblueprint
Autoblueprint's Avatar
Post Re: moog ball joint Castle Nut Torque
I have done quite a bit of suspension work over the years...so...just torque the nuts as tight as possible ( this would equate to around 90 to 100 foot pounds ) then keep torquing the nut tight till the cotter pin will slide in smooth...then fold one part of the pin over the nut and cut the excess and you are done.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 09-05-2011, 08:08 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Chevy Truck - Front Suspension Bolt Torque (ft. lbs.)�*
Model C-10 CP-20-30 K - All G-10-20 G-30
Lower Control Arm Shaft U-bolt 85 85 ----- 65 85
Upper Control Arm Shaft Nuts 70 105 ----- 70 105
Control Arm Rubber Bushings 115 ----- ----- 115 -----
Upper Control Arm Bushing Steel �� New 190 Used 115 ----- New 190 Used 115
Lower Control Arm Bushing Steel �� New 280 Used 115 ----- New 280 Used 115
Upper Ball Joint Nut * 50 ** 90 **100 *50 **90
Lower Ball Joint Nut **90 **90 ***80 *90 *90
Nut, Spindle To Knuckle ----- ----- 65 ----- -----
Crossmember To Side Rail � 65 65 ----- 65 65
Crossmember To Bottom Rail �� 90 90 ----- 90 90
Crossmember Brake Support Struts 60 60 60 60
Stabilizer Bar To Control Arm 25 25 Anchor Plate 130 25
Stabilizer Bar To Frame 25 25 .55 25
Shock Absorber Upper End 140 140 65 75
Shock Absorber Lower End 60 60 65 75
Brake Splash Shield To Knuckle 120 in. lbs. 120 in. lbs. 120 in. lbs. 120 in. lbs.
Wheel Bearing Adjustment ---- ---- Inner 35 Outer ��� ----
Wheel Bearing End Movement .001-.005" .001-.005" .001-.010" .001-.005"
Caliper Mounting Bolt 35 35 ---- 35
Spring - Front Eye Bolt ---- ---- 90 ----
Spring - Rear Eye Bolt ---- ---- 50 ----
Spring - To Rear Shackle Bolt ---- ---- 50 ----
Spring - To Axle U-Bolt ---- ---- 150 ----
Spring - Front Support To Frame ---- ---- 25 ----
Suspension Bumper 15 15 25 15
Stabilizer To Spring Plate ---- ---- 130 ----
* Plus additional torque to align cotter pin. Not to exceed 90 ft. lbs. maximum.
** Plus additional torque to align cotter pin. Not to exceed 130 ft. lbs. maximum
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-05-2011, 09:53 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i'll have to say I've never used a torque wrench for ball joints or tie rod ends either.
Old 09-06-2011, 08:55 AM   #6
kcfirstbuild
Confused by this ?
Old 09-06-2011, 11:11 AM   #7
muckyp
muckyp's Avatar
Confused me at first too. If you look at the very top of his post you will see it lists four models. Each number corresponds to a specific model. ie. The first number is for a c-10. At least that is what I think.
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 09-06-2011, 07:40 PM   #8
kcfirstbuild
ok thanks, for all the help. Just wanted to make sure I did it correctly.
