#76 |
Re: Power Brake Booster Adapter Bracket
Captainfab, will this work with a 72 power booster? I see your bracket on the booster side is drilled for 3 3/8w by 3 1/2 tall? Thats the bolt pattern on the booster i have. Pm me payment info please.
Thanks, Jeremy Last edited by 62 short step; 09-12-2011 at 02:40 PM. |
#77 |
60-66 Nut
I believe the '67-'72 boosters' stud pattern is 3-1/2" x 3-1/2". So some slight elongating of the holes will be necessary. I'll send you a PM
#78 |
Sent you a pm.
#79 |
60-66 Nut
Your booster bracket shipped today Jeremy. Thanks
#80 |
Thanks Captain!
#81 |
60-66 Nut
No problem Jeremy, I appreciate the business
#82 |
![]() Join Date: Dec 2010
Great design, excellent fit, here it is with the CPP booster master combo
#83 |
60-66 Nut
Thanks for the compliment and the installed pics.
![]() Did you have to elongate the holes in the bracket any for the CPP booster to bolt up?
#84 |
That combo has brackets bolted to it that you remove, if you leave those on then yes you would have to elongate the holes, the booster studs line up perfectly to your mount, and only about 1/4 inch adj is needed on the rod from pedal to booster. fit was perfect couldnt be better, I would have used your power steering adapter but I started this build and buying parts before I used this site. Its a great design, hats off to you Capt!
#85 | |
HOW long until spring??
![]() Join Date: Mar 2009
Update---- after about 5000 miles , I was tired of the vacuum brakes with a cam and low vacuum and a hard pedal. I removed the vacuum booster and installed a hydro boost from a 94 Astro van. I may have also had a bad vacuum booster all along. The hydro boost pump works on the same bracket I bought from John two years ago, but a new linkage to the pedal was built to adapt things Wow! what a difference . It will stop the truck really quickly without locking up the tires and skidding. Much better now!!!
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#86 |
60-66 Nut
Thanks for posting a pic of your updated brakes Bruce
#87 |
hey captain, thanks for the brake booster bracket! i got it today, nicely packed and sealed, thanks again! i'll will be installing it once i get my hydro booster hoses! does anybody have a p/n for the hydro booster hoses? i seen the other hose kits going for just under $300!
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
#88 | |
60-66 Nut
![]() Have you tried hoses for a '73-'87 hydroboost? Of course fitment is going to depend on what engine you are running and which water pump if a small block. Do you have any business local that make hydraulic hoses? Quote:
#89 |
i will have to check into the 73-87 hydroboost hoses! i'm using a smallblock and long water pump! there's a napa here in town that i think will make the hoses, and theres a hydraulic shop about two blocks from napa! i'm still in the beginning process of it all and just trying to get some info. thanks for your input and once again thanks for the bracket! i'll be installing it tomorrow and updating my thread with a few other things!
#90 |
NAPA made my hoses using 3000PSI hose and 3/8" compression fittings that they can crimp together.
The compression fitting works on both the existing steel line sets if you cut the old hoses off right next to the old crimp. The hydro boost uses metric O-ring and the gearbox and pump are flare. The compression fittings were about 10 bucks each ( need 4) and the hose was about 4 bucks a foot.
#91 |
Will the brake booster bracket bolt onto my truck firewall without drilling any new holes. If so, will it be plenty strong. I have a 1963 chevy 1/ 2 ton pickup with four wheel drum brakes. Updating to disc brakes in the front. I have purchased the CPP power brake booster with master cylinder kit from Ecklers trucks. Will it adapt to it? Thanks Jim
#92 |
Hey Cap,want to order a power booster bracket from you.Before I do,I wanted to know if your familiar with an MBM booster as this is the brand that my supplier sells.He tells me the 7" booster bolt pattern is 3 3/8 on center on all 4 studs on a zinc plated unit.The reason I ask is Im going with MBM stainless unit and want to make sure the bolt patterns dont change.MBM is closed till Monday,so if your not sure i can confirm with them then.
Thanks, Ed. ![]() |
#93 | |
Hey Cap,I should also mention that I have eliminated the standard trans and am now using a 2 peed powerglide and am wondering if that will change the bracket needed.This may be a moog question however I like to cover al bases !
Thanks, Ed ![]() Quote:
#94 | |
60-66 Nut
The booster hole pattern is 3-3/8" x 3-1/2" as noted in post #1, so you will have to elongate the holes slightly.
#95 |
60-66 Nut
The only way that could be an issue is if you are using a factory auto column, But since you are looking at a 7" booster, that shouldn't be an issue either way. With the larger boosters the trans shift rod can contact the booster when in park.
#96 |
Thanks for the help.The final advise I may need is what and where for the pushrod.My original seems to have disappeared !Maybe I can the that from you as well ?
Send me a PM with all info to get the bracket and if possible,pushrod too. Let know. Thanks, Ed. |
#97 |
60-66 Nut
I'm not familar with the MBM boosters, but most of the universal aftermarket boosters have a threaded pushrod. If that is the case, then one of the universal booster pushrods from Speedway may work. You might ask MBM if they offer anything. I'll send you a PM.
#98 |
Hello, I received the brake booster bracket for my 63 chevy truck today. Thanks! I'll be installing it this weekend. I am also wanting to put power steerring and air cinditioning on this truck, which will require me to move the alternator because I have a 292 6 cylinder. Any ideas? Thanks Jim
#99 | |
60-66 Nut
There is a guy on ebay that makes and sells PS and AC brackets for the Chevy I6 engines. They look to be well made.
http://www.ebay.com/itm/PS-P-S-POWER...item4ab06ccfe2 Quote:
#100 |
Just received by booster bracket,and would like to add that is is a very well made product.I was so impressed,I took it down to the local Rod shop to show it off ! Many compliments on the great work Cap,you will come highly recommended.
Thanks, Mr.Ed |
