Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 11-05-2011, 11:09 PM   #1
Captainfab
60-66 Nut
Re: Power Brake Booster Adapter Bracket
The only way that could be an issue is if you are using a factory auto column, But since you are looking at a 7" booster, that shouldn't be an issue either way. With the larger boosters the trans shift rod can contact the booster when in park.
Originally Posted by lenguini View Post
Hey Cap,I should also mention that I have eliminated the standard trans and am now using a 2 peed powerglide and am wondering if that will change the bracket needed.This may be a moog question however I like to cover al bases !
Thanks,
Ed
Old 11-06-2011, 11:10 AM   #2
lenguini
lenguini's Avatar
Thanks for the help.The final advise I may need is what and where for the pushrod.My original seems to have disappeared !Maybe I can the that from you as well ?
Send me a PM with all info to get the bracket and if possible,pushrod too.
Let know.
Thanks,
Ed.
lenguini is offline   Reply With Quote
Old 11-06-2011, 11:45 PM   #3
Captainfab
60-66 Nut
I'm not familar with the MBM boosters, but most of the universal aftermarket boosters have a threaded pushrod. If that is the case, then one of the universal booster pushrods from Speedway may work. You might ask MBM if they offer anything. I'll send you a PM.
Let know.
Thanks,
Ed.
Old 11-22-2011, 10:57 PM   #4
lenguini
lenguini's Avatar
Just received by booster bracket,and would like to add that is is a very well made product.I was so impressed,I took it down to the local Rod shop to show it off ! Many compliments on the great work Cap,you will come highly recommended.
Thanks,
Mr.Ed
Old 11-23-2011, 12:27 AM   #5
Captainfab
60-66 Nut
Thank you much for the compliment Mr. Ed
Old 11-29-2011, 12:09 PM   #6
poldenbuttel
Your brackets are a site for sore eyes. Thank you for offering these great products. I have sent you a PM to order a Booster bracket for a 67. Look forward to hearing from you.
poldenbuttel is offline   Reply With Quote
Old 11-29-2011, 05:27 PM   #7
chevyrestoguy
chevyrestoguy's Avatar
Cap'n:
I am going to be running your bracket with a factory auto column and the booster you specified in Post #1. Do you think the shift rod might hit in this configuration? The reason why I'm asking is that I haven't bought a booster yet. If it might hit, I'll look for a smaller booster.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 11-30-2011, 12:30 AM   #8
Captainfab
60-66 Nut
On my '66 Suburban, I have a factory auto column. I am running a '72 Impala booster, and I had to trim a little off of the rod that goes down to the trans, and also I made a slight dimple in the booster for a little added clearence. I have not noticed any issues resulting from the dimple.
I don't remember for certain the diameter of the Impala booster, I will have to verify that. I believe the S10 boosters are a little smaller diameter.
Originally Posted by chevyrestoguy View Post
Cap'n:
Old 12-01-2011, 12:00 AM   #9
Captainfab
60-66 Nut
The overall diameter of the '72 Impala booster on my Suburban is aprox 10.5". The '88-'98 full sized truck boosters are the same size.
