Old 10-07-2011, 12:05 AM   #1
KroAutomotiveInc
KroAutomotiveInc's Avatar
E Brake help!
where can you find e brakes for these truck ive bought the ones from Napa/checker and there not even close i couldn't even figure out away to make them work anyone know? or had luck with the ones at the parts store
KroAutomotiveInc is offline   Reply With Quote
Old 10-07-2011, 12:39 AM   #2
Captainfab
60-66 Nut
Re: E Brake help!
Exactly which part of the e-brake are you looking for? The cables? If so what year truck? Have you converted to an auto trans?
Old 10-07-2011, 01:37 AM   #3
KroAutomotiveInc
Re: E Brake help!
its a 1964 i need the 2 long ones that head for the drums and no still the 4 speed
Old 10-07-2011, 01:39 AM   #4
KroAutomotiveInc
Re: E Brake help!
o yes the cables lol
Old 10-07-2011, 09:18 AM   #5
Clyde65
Clyde65's Avatar
Re: E Brake help!
I converted my 65 to the 66 type set up. 66's didnt use the transmission crossmember as a pivot point. pretty easy to do.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-07-2011, 10:00 AM   #6
brawley
Easy Does It
brawley's Avatar
Re: E Brake help!
how do the 66's hook up ?? any pics.
brawley is offline   Reply With Quote
Old 10-07-2011, 02:06 PM   #7
KroAutomotiveInc
Re: E Brake help!
and where did you find the cabels?
Old 10-07-2011, 02:13 PM   #8
Woogeroo
Wink Re: E Brake help!
Most of the vendors that sell parts for our trucks sell the e brake cables. There are different lengths, one for the short and the other for the long... other than that everything should be the same.
e brake layout pics and other pics of the brakes
The Chevy/GMC parts vendors list
The Vendors Marketplace here at the 67-72chevytrucks.com forum.
good luck.
-W
Woogeroo is offline   Reply With Quote
Old 10-11-2011, 07:04 PM   #9
KroAutomotiveInc
Re: E Brake help!
anyone bought these before brake cables out of lmc catalog for a 1964-65 long bed and do i need o buy the brake cable seal set?
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=95
Old 10-12-2011, 02:34 PM   #10
KroAutomotiveInc
Re: E Brake help!
these appear to be what was on my truck from a 1974 c20
http://www.oreillyauto.com/site/c/de...3342&ppt=C0009
Old 10-12-2011, 03:54 PM   #11
Clyde65
Clyde65's Avatar
Re: E Brake help!
These are what I bought for my truck, well the middle cable and the front cable. the front cable is mad of aluminum or light steel and would pull right through the hold down bracket when you pulled it, I modded my old one and it works fine. I had to mod my middle cable since I was using the 65 rear cables though.
Clyde65
Rebuild of Clyde
support our troops!
Old 10-12-2011, 04:28 PM   #12
dracko
dracko's Avatar
Re: E Brake help!
Do they sell the rubber boots that sit where the cable goes into the ribbed tube? My e-brake froze up a few times last year and i'm thinking its from moisture getting past those seals. Had to carry a MAP torch around just in case, lol.
dracko is offline   Reply With Quote
