Closed Thread
Old 10-22-2011, 07:21 PM   #126
hb32
hb32's Avatar
Re: What Did You Do With Your Truck Today ?
Originally Posted by waybad View Post
hey hb32 ,, you need to do this for your shifter..(make it a short throw)
It works great,, did it to mine..
http://www.stovebolt.com/techtips/shifter/index.html
Just finished and really does work great. The hardest part was the 1 inch spacer and took several hours but worth the effort. Thanks for the heads up.
Life is too short to drive a boring vehicle.
hb32 is offline
Old 10-22-2011, 09:36 PM   #127
chinquipin
Drug my cab out and started grinding out some rust and removed the seat frame.
Long way to go
chinquipin is offline
Old 10-23-2011, 12:01 AM   #128
therapy
therapy's Avatar
Started tearing it apart..I just got a 50 5 window...WOOO HOOOO
therapy is offline
Old 10-23-2011, 12:54 PM   #129
OldUsedParts
OldUsedParts's Avatar
Since I will be installing my new Fenton Headers and Offy dual single bbl intake soon (gonna have lots of question when that happens - lol) I decided to paint the Oil Filter Canister and move it from the intake manifold to the inner fender wall. The smudges are only reflections in the silver paint - - - that Ace Hwd paint sure held up good thru all my beating, banging, cussin' and fussin' !
"Real Cowboys are not a vanishing breed, they are just very hard to see from the Highway"
OldUsedParts is offline
Old 10-23-2011, 05:32 PM   #130
alden
alden's Avatar
I'm 8 screws short to have everything in place, but the bed wood is sealed, cut, and mounted. Still have to get the fenders widened but this will work for the time being.
alden is offline
Old 10-24-2011, 06:18 PM   #131
OrrieG
OrrieG's Avatar
Nothing, 64 Chevelle was feeling lonely and puked the heater core. I love old cars, 20 minutes to pull the heater housing (had it out 5 years ago so know the drill), $40 for a new core and probably 1/2 hour to get it back together.
OrrieG is offline
Old 10-24-2011, 08:09 PM   #132
mknittle
mknittle's Avatar
i did some more work on the cross-member that attach the upper control arms for my rear suspension.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 10-24-2011, 09:26 PM   #133
Purec4
Purec4's Avatar
Not much, picked up some angle iron to use for floor brace. And rested from my 8 hour bash yesterday...... dang I hate getting old.....
We lust for what we want, weep for what we need...
Purec4 is offline
Old 10-25-2011, 09:35 AM   #134
mknittle
mknittle's Avatar
I can't see it yet.
Mark
My GMC build.
mknittle is offline
Old 10-25-2011, 01:33 PM   #135
FFredo
My garage is a pit of darkness smelling of leather dye.
The Apache is still running strong but I can feel it's hatred for me as I force it to go around with out a bed.
The shame...
FFredo is offline
Old 10-25-2011, 04:20 PM   #136
Johnny49
New fan belt, new thermostat, fixed heater hoses, drained radiator and filled with fresh 50/50 (starting to get chilly here in New England)... Now all I need is a little more money to fall from the sky so I can get the two brake drums I need to finally put this thing on the road again. Really want to do it before the snow flies!
Johnny49 is offline
Old 10-25-2011, 09:06 PM   #137
Purec4
Purec4's Avatar
Welded in bracing for the passenger side floor and measured up templets for the flooring. Anybody give me some placement measurements for where the shifter comes up through the floor on a T-5 trans.
Purec4 is offline
Old 10-25-2011, 10:18 PM   #138
mknittle
mknittle's Avatar
The shame...
LOL How's that coming along?
Mark
My GMC build.
mknittle is offline
Old 10-25-2011, 10:40 PM   #139
FFredo
Mark, I should finish this leather order by tomorow. I had "planed" to finish the bed this week but I need to address a new problem with the front brakes on the 59. Also I really need to get at the steering free lash so I dont go down the road fighting to stay in my lane. I want to take it on my first real trip in two weeks. A big party in Niland Calif AKA Slab City.
FFredo is offline
Old 10-26-2011, 07:32 PM   #140
Atommik
Atommik's Avatar
Finished the metal work on the right rear fender, now a little filler and primer. Slowly but surely it will get finished!!
Atommik is offline
Old 10-26-2011, 11:22 PM   #141
mknittle
mknittle's Avatar
It seems like these things know when you have something else planed.
what kind of leather work do you do?
Mark
My GMC build.
mknittle is offline
Old 10-26-2011, 11:28 PM   #142
mknittle
mknittle's Avatar
still working on the cross member I may get to the control arm mounts after I get back from my cancer doctor tomorrow morning.
Mark
My GMC build.
mknittle is offline
Old 10-27-2011, 07:35 PM   #143
Russell Ashley
Russell Ashley's Avatar
Tightened up my hood hinges. Was going to buy new ones but decided to fix my old ones instead. Most of the wear was in the arms that hold up the hood where the bracket bolts to the hood. With the hood hinges raised to the max you could move the front of the hood up several inches due to the slop in the pivots. I punched out the pins and drilled out the holes using a 1/2 inch bit. I made some new pivot pins, put the bracket back on and welded the pins in. I ground the welds down to make the brackets fit back on to the hood as there isn't much room there. The other pivots were tight but I heated them and peened them to be sure.
The hinges feel tight now so maybe with new springs they will hold the hood up better than before.
I made the pins out of 3/8th bolts. Just turned part of the head down to make the pivot and turned the body down to fit into the bracket, and cut them to length.
Russell Ashley is offline
Old 10-27-2011, 08:20 PM   #144
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Scraped my camaro project and moved the '57 Stepper to the front of the line.. Gonna be a busy winter in the garage ... can't wait to get out there next weekend and start cleaning up the garage.
87Lowrider is offline
Old 10-31-2011, 01:53 PM   #145
55metalmonkey
took the box off (again!!!) started to tub the box for wider wheels, should be done tonight, plan on rounding the top rear edge after that and filling the steak pockets and front edge.
55metalmonkey is offline
Old 10-31-2011, 01:58 PM   #146
Dan in Pasadena
Dan in Pasadena's Avatar
Wet sanded the lower part of my dash in the never-ending saga that the improving my interior has become. Pictures will be in my own thread one of these DECADES! Jeez.
Dan in Pasadena is offline
Old 10-31-2011, 02:29 PM   #147
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Took everything off the frontend in prepartion to install drop spindles. Not much else.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline
Old 10-31-2011, 03:25 PM   #148
texas56
texas56's Avatar
Wish I would have got some done on mine, but worked on my sons 86 project....I did get mine washed though
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline
Old 10-31-2011, 06:56 PM   #149
nels1954
nels1954's Avatar
Today I drove my truck. Have spent the last year working on the truck. I now have a new 261 engine with a 5 speed transmission. It has been a long time working on the truck in my garage. Winter is coming. Trying to enjoy the truck before the weather changes.
nels1954 is offline
Old 10-31-2011, 08:34 PM   #150
mknittle
mknittle's Avatar
looks great
Mark
My GMC build.
mknittle is offline
Closed Thread
