Old 10-16-2011, 03:23 PM   #11
waybad
waybad's Avatar
Re: What Did You Do With Your Truck Today ?
Originally Posted by hb32 View Post
Thanks and had thought of using a internal wrenching bolt but had the grade 8`s from another project at hand. When I got the trans, I pullled 2 on the same day, one had torx drive bolts, which I suspect was the fix from GM which won`t work in our case as they are metric, and the other was missing that bolt. I ground down a 3/4 wrench for clearance and appears to have solved that issue. Found out on removal about the lower bolts and will install with the nut on the trans side so should have no issues with the clearance.
I hope to have it all back together shortly and then need to find a drive shaft.
What did you use?
hey hb32 ,, you need to do this for your shifter..(make it a short throw)
It works great,, did it to mine..
http://www.stovebolt.com/techtips/shifter/index.html
waybad is offline
