Old 10-24-2011, 02:00 AM   #1
darkone
adding a tach dash: do i need anything besides the harness?
hey all, i have a 70 chev 350 v8 with HEI that I recently bought (havent installed yet) a restored tach dash for. just wondering if there is anything i need to buy to make the tach work when using the hei dist. thanks in advance for any knowledge you may have regarding this subject
darkone is offline   Reply With Quote
Old 10-24-2011, 10:51 AM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: adding a tach dash: do i need anything besides the harness?
The tach should work fine. Try and find a factory clip connection for the harness to the distributor. Will make a clean connection and can't come loose.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-25-2011, 01:15 AM   #3
darkone
that will be okay for a hei coil distributer?
